Results 1 to 3 of 3
Thread: 1JZ ISCV Valve question..
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    Default 1JZ ISCV Valve question..
    so there is 2 to pipes on the valve that have water running in/out of them, does it matter which way the water flows through??
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    Default Re: 1JZ ISCV Valve question..
    Nope, and its also not needed at all, unless your area is prone to freezing.
    The water passage is purely there to stop the valve from freezing solid on cold mornings
    Apr 2008
    Win.. cheers for that.
    BURN RUBBER
  1. purge valve and iscv on 20v using microtech
    By deltathing in forum Tech and Conversions
    Last Post: 13-01-2006, 03:12 AM
