Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: supra mkiv 1jzgte swap help needed
    Aug 2011
    lincolnshire
    Default Re: supra mkiv 1jzgte swap help needed
    i have matched up what i think from your wiki and i have these left that im not sure what to match them to.
    12v alt to charge
    park neutral detection
    m-rel which i have connected to a live constant
    tb dash ignition power
    starter signal to dash
    e1 dash ground
    gnd for exhaust temp
    and
    power to auto trans
    the others i think are right the car goes to start but cuts straight out refusses to idle.
    and i have no life on the auto trans switches.
    also on 1 of the plugs theres a black/yellow wire which is thicker than most of the other wires.
    cheers lee
    If you also list the plug and pin numbers of the wires you haven't been able to match that would be helpful for us to help you
    Read this page in regards to the M-REL engine ecu pin.
    wilbo666 / M-REL - 6 Wire Idle Speed Control Valve (ISCV) Wiring
    Pin 23 on the below plug (JZA80 side) needs to be connected to IJ1 Pin 10 to power the auto trans shifter (so you get indication on the dash etc) and it also powers the speed sensor.
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2011
    lincolnshire
    thanks for that i connect the speed sensor power and auto trans power ign pin10 ij1 to pin23 on the supra orange plug but found i had no batt light or engine light. but i did have auto trans power. so alternativly i changed pin 23 to go to black/yellow on 1j2 12v to alt to charge and put the
    pin 10 ij1 to black/orange of ij2 and black/orange of the ik2 i had auto trans power and batt/ engine light come on and go off when its started. would this work ok.
    i am now stuck with the fuel pump and also the tachometer which i need to do the mod.
    and these are the wires i have remaining?
    white/red ij2 pin2
    brown/yellow ij2 pin9
    black/white ij1 pin6
    ik1 green/orange pin3
    ik1 black/yellow pin14
    1j1 red/green pin14
    and the white plug yellow pin12,green/blue pin7, green pin9,black pin10.
    these are the fuel wires i have
    ij1 fp diag pin1 green wire
    ij1 di fuel pump control signal pink wire pin8
    ij1 fpc power fuel pump control signal pin14
    and i left the thick black/red ij pin12 direct to battery as i still
    and on the supra
    pin4 fuel pump control purple/white
    pin8 fuel pump diagnostic blue/red
    pin12 fuel pump ecu green wire.
    all on supra gray plug.
    i connected them but heard no prime from fuel pump.
    or is it cuz got to earth it some where or missing something.
    thanks loads wilbro cheers lee
    Aug 2011
    lincolnshire
    i just had it running for a while by running the pump straight to the batt on and off because it will cut out if i leave it on constant.
    oh and now my temp gauge does work now the car run for longer but i havent sourced a middle pipe exhaust for the car yet.
    cheers lee
    Quote Originally Posted by leeti View Post
    To be honest it is pretty hard to follow what you are talking about there - it is very confusing the way you have worded what you have done
    white/red ij2 pin2
    1j1 red/green pin14
    I suggest that you also list the function of the pin / wire, such as follows...it does make it easier
    *IJ2, Pin 2, White/Red, ?
    *IJ2, Pin 9, Brown/Yellow, OD, Overdrive Disable
    *IJ1, Pin 6, Black/White, NSW, Park/Neutral Detection
    *IK1, Pin 3, Green/Orange,VF Diag Connector, Used for 'Voltage Feedback'
    *IK1, Pin14, Black/Yellow <THIS WIRE COLOUR DOESN'T MATCH YOUR PICTURE>...
    And matching...
    *IJ2, Pin 9, Brown/Yellow, OD, Overdrive Disable --> JZA80 90980-11562 plug, Pin 11, OD1
    *IJ1, Pin 6, Black/White, NSW, Park/Neutral Detection --> JZA80 90980-11469 plug, Pin 7, NSW
    Note: This is the pin that should be sending power via the auto trans park/neutral switch to the fuse box mounted starter relay to allow the engine to be started... the fact that you can start the engine at the moment without this connected properly means you have something in the wiring bypassed or wired incorrectly
    *IK1, Pin 3, Green/Orange,VF Diag Connector, Used for 'Voltage Feedback' --> JZA80 90980-11469 plug, Pin 13, VF1
    Matching...
    IJ1, Pin 1, Green, FP, Diag Connector Fuel Pump Connection --> JZA80 90980-11469 Plug, Pin 8
    IJ1, Pin 8, Pink, DI, Fuel Pump Control ECU Diag --> JZA80 90980-11469 Plug, Pin 12
    IJ1, Pin 14, ?, FPC, Fuel Pump Control ECU Signal --> JZA80 90980-11469 Plug, Pin 4
    I believe that this wire is the output to the fuel pump ecu in the JZZ30. I believe that the JZA80 fuel pump ecu power feed takes a different route so you should be able to leave this disconnected I believe.
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2011
    lincolnshire
    sorry for the crap write up wilbro. i did do it propley but my net went off when i was posting it lol well better than what i ended up doing lol.
    1 did connect them 3 wires but nothing seemed to happen ill try again anyway.
    the black/white wire there are 2 one on ij1 pin9 and 1 on 1j2 pin6 so i put the nsw off the ij1 pin9 to the supra nsw?
    will the car idle ruff with just the downpipe on as im next to find a centre pipe.
    thanks lee
    Aug 2011
    lincolnshire
    i have put the exhaust on and the car sounds like its running on so many pots or shall i say lumpy and its very smokey. any idea have i got something wrong i wounder?
    ill put a vid on soon of it running.
    lee
  1. new member supra mkiv 1jzgte
    By leeti in forum Toymods Car Club Membership and Feedback
    Last Post: 03-09-2011, 08:03 AM
  2. mkIII supra 1jzgte vvti motor swap questions
    By supradrew in forum Tech and Conversions
    Last Post: 28-01-2011, 01:00 AM
  3. FMIC ducting for a mkiv supra
    By natett in forum Tech and Conversions
    Last Post: 03-12-2010, 12:26 PM
