Results 16 to 30 of 37
Thread: supra mkiv 1jzgte swap help needed
    Aug 2011
    lincolnshire
    Default Re: supra mkiv 1jzgte swap help needed
    i have still got them and i got the supra male plugs to
    How / why did they get chopped off?
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2011
    lincolnshire
    Here are the soarer plugs apart from the two whit ones which ive left on the loom.
    [IMG][/IMG]
    Aug 2011
    lincolnshire
    And here are the two supra plugs,i also have a white one.
    [IMG][/IMG]
    May 2007
    what about the main plugs that plug the engine loom into the ecu and the ecu itself?
    Aug 2011
    lincolnshire
    yeah there behind the carpet pluged in.
    Aug 2011
    lincolnshire
    can i not join the 1jz wires to the male supra plug wires then plug them in or are thay wired differently.
    May 2007
    Quote Originally Posted by leeti View Post
    you can but it just makes it harder for us to tell you what needs to go to what without the plug being there as most diagrams have plug pins numbered...
    but seeing how you have the plugs still it should be ok... will just make things a little more difficult/time consuming
    Aug 2011
    lincolnshire
    yeah i have every pin numbers and colour and what it does for both looms.
    but therenamed differently on the 1jz to the supra.
    ill post what i think is right
    Aug 2011
    lincolnshire
    i have had another hr on joining wires and i have batt light and the other simbels next to batt light thay go off when i start it.
    and the imobilizer red light has gone dimmer so wrong somewhere.
    i still not got temp gauge,tacho meter and the auto trans gear indecators on dashor dont i really need them.
    no reverse lights is it because i need to power up something.
    theres a black and orange thin wire on to other plugs thats apart from the main 2 b/o wires and i have 1 b/o on the supra orange plug thin wire. any ideas thanks lee
    Aug 2011
    lincolnshire
    ik1 plug
    [IMG][/IMG]
    ij1
    [IMG][/IMG]
    ij2
    Aug 2011
    lincolnshire
    ill get the white plugon soon
    Aug 2011
    lincolnshire
    would the car run crap if i dident have the centre peace of exhaust on
    This is my rough guide to the JZZ30 Engine to Body loom pinouts to match the images you have. There are a few pins (~5) that I can't find on the dodge diagrams that I have... but that shouldn't be too much of a concern at this stage... there also might be a few mistakes
    You've left out a number of pins in your notebook, is this because you have connected them?...
    You'll also notice how I haven't used wiring colors - they can (and do!) change very often over the period of time a car is manufactured... pin and plug numbers are a much better way to go in my opinion
    If you take the below you should be able to match the wires up with the 2JZ-GE Engine to Body loom pinouts on my wiki (which I've posted before).
    I'd also suggest writing down as you go exactly which wire/s you have connected to where etc to keep a log.
    Code:
    Plug	Pin	Name	Function
    IK1	1	TC	Diag Connector - Used to Enter Test Mode for Cruise Control, AC, etc
    IK1	2	TE2	Diag Connector - Used to Enter Test Mode (Similar to TE1)
    IK1	3	VF	Diag Connector - Used for 'Voltage Feedback'
    IK1	4	TE1	Diag Connector - Used to Enter Test Mode (Flash Check engine light)
    IK1	5	TT	Diag Connector - Used for Diagnostic
    IK1	6		Speed Sensor GND
    IK1	7		Speed Sensor Signal to Dash
    IK1	8		Tacho
    IK1	9		Water Temp Gauge
    IK1	10	?	?
    IK1	11	R	Reverse, Auto Trans Switch
    IK1	12	P	Park, Auto Trans Switch
    IK1	13	N	Neutral, Auto Trans Switch
    IK1	14	D	Drive, Auto Trans Switch
    IK1	15	/	/
    IK1	16	2	2, Auto Trans Switch
    IK1	17	L	L, Auto Trans Switch
    IK1	18	W	Check Engine Light
    IK1	19	EGW	Exhaust Gas Warning Light
    IK1	20		Oil Pressure
    IK1	21	PWR	Auto Trans PWR/NORMAL Switch
    IK1	22	OD2	Overdrive Disable
    IK1	23		Engine Oil Level Sensor
    Code:
    IJ1	1	FP	Diag Connector - Used to allow the fuel pump to be tested by bridging +B to FP inside the diag connector box on the engine
    IJ1	2	?	?
    IJ1	3		Power to Injectors 2, 4, & 6
    IJ1	4	/	/
    IJ1	5	L	Alternator Charge Warning Light
    IJ1	6	NSW	Park/Neutral Detection
    IJ1	7		Power to Injectors 1, 3, & 5
    IJ1	8	DI	Fuel Pump Control Diagnostic Signal
    IJ1	9	/	/
    IJ1	10		Speed Sensor Power & Auto Trans Position Switch Power (IGN)
    IJ1	11	ELS	Electronic Load Sense Idle Up
    IJ1	12	+B	M-REL Switched Power to Fuel Pump ECU
    IJ1	13	/	/
    IJ1	14	FPC	PWM Fuel Pump Control Signal
    Code:
    IJ2	1	IDL	Throttle Position Idle Output from Engine ECU
    IJ2	2	?	?
    IJ2	3	SP1	Speed Signal From Dash to Engine ECU
    IJ2	4	/	/
    IJ2	5	/	/
    IJ2	6	SOL-	Proportional Power Steering
    IJ2	7	STP	Stop Light Switch Input
    IJ2	8	/	/
    IJ2	9	OD	Overdrive Disable
    IJ2	10	?	?
    IJ2	11	IGSW	Ignition Switched Power to Engine ECU
    IJ2	12	/	/
    IJ2	13	?	?
    IJ2	14	/	/
    IJ2	15	/	/
    IJ2	16	SOL+	Proportional Power Steering
    IJ2	17	/	/
    Code:
    CI2	1	TB	Dash Ignition Power?
    CI2	2	WA	Diag Connector - ABS
    CI2	3	/	/
    CI2	4	/	/
    CI2	5	/	/
    CI2	6	/	/
    CI2	7	TEM	Diag Connector - TEMS?
    CI2	8	/	/
    CI2	9	CCO	Exhaust Gas Temperature Sensor
    CI2	10	ST	Starter signal to dash
    CI2	11	E1	Dash Gnd
    CI2	12	T	Injector Signal to Dash for Fuel Economy Calcs?
    CI2	13	/	/
    CI2	14	/	/
    CI2	15	/	/
    CI2	16	/	/
    CI2	17	/	/
    CI2	18	/	/
    CI2	19	/	/
    CI2	20	/	/
    CI2	21	/	/
    CI2	22	/	/
    CI2	23		GND for Exhaust Gas Temperature Sensor
    CI2	24	/	/
    CI2	25	TS	Diag Connector - ABS
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2011
    lincolnshire
    thanks very very much for that wilbro
    im going to get the pen out again now and give it a go.
    i appriciate that thankyou. the wires i listed was the only 1s i could fined.
    ill let u no shortly what i get joined.
    cheers lee
  1. new member supra mkiv 1jzgte
    By leeti in forum Toymods Car Club Membership and Feedback
    Last Post: 03-09-2011, 09:03 AM
  2. mkIII supra 1jzgte vvti motor swap questions
    By supradrew in forum Tech and Conversions
    Last Post: 28-01-2011, 02:00 AM
  3. FMIC ducting for a mkiv supra
    By natett in forum Tech and Conversions
    Last Post: 03-12-2010, 01:26 PM
