hey champ, the rear shocks are easy, just a couple of bolts, the front 1s are a bit more complicated as they are struts, prob best to get some1 that knows wat they are doing if your not very mechanically minded.try repco for the shocks, well for all the parts, if you buy them all at the same time they should give you a discount.
the sway bar bushes will be easy, just a few bolts to undo, pull the old 1s out and slip the new 1s in, adjusting the steering box is easy, but if its too far gone will need a new 1, you need to slightly undo the nut on the top (there will be a flat screw in the middle of it), then tighten the screw a little and then tighten the nut up, try the steering and repeat until it feels a bit tighter, dont make it too tight tho as it might make the box wear quicker.
i would think just to replace the whole tie rod, water pump betlt is just the fan belt, easy as just loosening the alternator so you can move it to allow the belt to come off, then just put new 1 on (they are about $15 i think) put some pressure on the alternator to tighten the belt and then tighten the alternator up.
im not sure on the rear extension housing maybe some 1 else on here can explain.
the tappet cover isthe top of the engine, you will need to take off the air cleaner and then just unbolt the cover, buy a new gasket, clean all the oil and crud off where the gasket sits, hey maybe even buy some paint and paint the cover topretty it up a little while its off, then just bolt it back on with the new gasket in place.
hope this sorta explains a little, if you send me your email address i can send you a pdf file that shows exploded views of the car in bits, it will show you how things go together, might be of some help, but im sorry i dont have a repair manual as yet
some ppl might give you a hard time bout the simplicity of some of your questions, just ignore them and dont be disheartened, give it a go and if it dont work out then get a mate round that has some experience, give him a 6pack (dont let him drive home tho!!) to show or help you out.
krem
i appreciate it a truck load. I checked out the shocks earlier today and found out they are struts. Dad is down and he said ideally if we jack up the front then we won't need a spring compressor?
