Results 1 to 8 of 8
Thread: 4AGE 20V Timing Belt Crank Pulley...
    Beer anyone?? Domestic Engineer Just1n_mc's Avatar
    Default 4AGE 20V Timing Belt Crank Pulley...
    So i've managed to break the crank pulley that sits behind the harmonic balancer to run the timing belt when I pulled it off my silvertop and need to buy a new one. I've rang Toyota to try and replace it but they tell me it's ex-japan and at least 4-6 weeks away. The problem I have is that i'm meant to be racing at Winton in a month which means I need to get one sooner so I can run the motor in before I race it.
    The question I have is does anyone know if a 16V crank gear is the same as a Silvertop?
    1970 2M MS55 Crown - Weekend Cruiser.
    1970 2R RT40 Corona - Cruising Grandpa Style
    1986 20V 4AGE AE82 Corolla - The Brown Racecar.
    1988 4AGE AW11 MR2 - Sold but not forgotten
    1992 1MZFE SW20 MR2 - Sold Supercharged V6 Monster.
    Default Re: 4AGE 20V Timing Belt Crank Pulley...
    Hi mate
    I should have one on my spare motor that i could post to you.
    I'll check today and let you know.
    Cheers Craig
    That would be awesome if you could.
    Something I forgot to add is can you re-use head bolts on the 20v? I'm in the same situation with Toyota as they have nil stock Australia wide.
    oregon
    the factory 16V head bolts are NOT torque to yield, I don't KNOW if the 20V ones are.... but if I were to guess - they likely can be reused.
    The 20V silvertop crank pulley is the same as the 16V crank pulley, the blacktop pulley shows a different part number
    Just checked my block i have a pulley just got to get it off then i'll post it to you.
    yeh you can reuse the head bolts, you are meant to check the length to make sure they are within specs.
    Cheers mate that would be awesome.
    Does anyone know where I can find the length specs for the head bolts?
    116.5mm max length from bottom of the head to the end
  1. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 06:06 PM
