Results 1 to 4 of 4
Thread: testing tridon thermo fan switch
    May 2006
    tas
    Default testing tridon thermo fan switch
    I brought this about 2 months ago
    TFS213 Fan switch
    Thread - M22 x 1.5
    Circuit - Dual Normally Open - Normally Open
    Temp Range: 95ºC to 90ºC and 102ºC to 97ºC
    Spanner - 22mm
    Replaces original black part.
    Now im not completely sure if its faulty or not.
    The first circuit seems to be coming on at 95deg but the second one isnt. I was testing by putting into a pot of shallow water on a gas burner. Had it going flat-out but the second one still didnt come on. I dont have a thermometer that i can stick in the pot but im pretty sure it should be soaking up more then 102deg so it should come on right?
    I have the main pin connected to +12v and using a multi meter to probe the other two pins
    Just want to make sure before i go back and try and claim warranty because they are insisting it has to be sent back for testing. I noticed when i had a overheating issue that the second fan didnt come on and thought it probably would have done so this prompted me to test it.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Default Re: testing tridon thermo fan switch
    Water boils at 100 deg, so I wouldn't think it would get any hotter than that without coolant. Or would it?
    Correct. You can try and add a fist full of salt, which will raise the boiling temperature... and maybe enough to hit 102 degress.
    Mind you, give it a good wash afterwards to remove the salt.
    seeyuzz
    river
    May 2006
    tas
    okay ill pull it out again tomorrow and try some salt in with it. Dont think id like to boil coolant if i can help it, may not be so food safe lol.
    -JZX83 in the build
    <3 7M sludge pump
  1. Tridon Thermo Fan Switch Catalogue
    By CrUZida in forum FAQ
    Last Post: 30-08-2010, 10:03 AM
  2. RG thermo switch.
    By maurice c in forum Tech and Conversions
    Last Post: 11-06-2008, 09:50 AM
  3. Tridon Thermo Switch Catalog
    By infotechplus in forum Tech and Conversions
    Last Post: 22-02-2007, 06:16 AM
  4. Tridon Thermo Fan Switch Catalogue
    Last Post: 03-04-2006, 02:22 PM
