Results 1 to 12 of 12
Thread: Oil cooler on 7AFE
    Jun 2011
    Default Oil cooler on 7AFE
    Hi guys,
    Just found out the oil cooler hoses on my 7AFE have started to leaks. Looking to install an aftermarket oil cooler just to prepare for the summer.
    Is any one know if our stock 7A or 4A sandwich block is equipped with thermostats or not?
    Default Re: Oil cooler on 7AFE
    No thermostats, it is spring-loaded though so will only open when oil pressure is high enough.
    Jun 2011
    If its opened when oil pressure is high, is that means under normal engine operation it bypass the oil cooler as well?
    oregon
    I recommend Mocal. They have a very nice thermostatically controlled adapter
    Aug 2009
    What's the cost for a Mocal set up?
    May 2010
    TAS
    I paid around $200 aus dollars for mine.
    Be aware they require a NPT to BSP adaptor fitting (if you wish too run NPT -10 fittings and lines)
    And they need to have a 1/2 dowty seal on the plate/bsp side, which are a washer with a rubber 'O' ring contained inside or it will leak.
    oregon
    I run mine with -8 lines and everything is tight and dry (5400 miles on set-up so far) When I ordered my adapter the salesman asked me what hardware I was going to run (-8) and then supplied all the fittings and seals for the plumbing.
    You may have to modify the engine mounts to provide clearence for the thermostat part of the assembly
    the adapter was about $90, the cooler was about $130 (curved cooler*) and the lines and fittings cost me about $80-$100
    Aug 2009
    Yeah interesting stuff about the different threads...
    I'm guessing -8 & -10 refer to braided pipe sizes or am I way off ???
    I've got a GZE adaptor & cooler ...but also considering oil filter relocation.
    Since installing headers on the 4afe some time ago and having difficulty undoing exhaust connecting bolts, I found servicing the filter a PIA
    Quote Originally Posted by PrettyCoolWagon View Post
    AN thread - Wikipedia, the free encyclopedia
    Aug 2009
    Thank you kind sir
    Jun 2011
    Where can i get the $90 deal for the thermostats block? Is it mocal brand as well?
    oregon
    Quote Originally Posted by AE112R View Post
    Importer/Distributor - BAT, Inc.
    7630 Matoaka Rd.
    Sarasota, FL 34243
    (941) 355-0005
    Fax (941) 355-4683
    http://208.109.215.220/files/sp1t.pdf
  1. can an engine oil cooler be used for auto trans cooler
    By Mr DOHC in forum Tech and Conversions
    Last Post: 09-05-2006, 06:12 PM
