Will the rods be custom as well? Stock 7AFE rod length is 132.5 - which you have acknowledged (in your calcs). Some websites offer to get Pauter Rods made slightly modified for the same price as the off the shelf rods. With your R/S ratio of 1.48, I would imagine the rev limit shouldn't be much higher than 6500rpm, based on anecdotal comments from other forums and charts of rod stroke ratios for production engines that I've seen.
) copy of engine analyzer pro, peak power for the kelford cams with the timing I had set is about 6500rpm anyway and at 8000rpm max piston speed is like 4800fpm...
