Results 1 to 15 of 16
Thread: What pre pump for surge tank? 4agze
    broom broom Automotive Encyclopaedia poida's Avatar
    Default What pre pump for surge tank? 4agze
    Hi Guys,
    I have a surge tank in my boot and need to replace my pre pump because its old I don't trust it.
    Looking at this pump Inject-a-Carb
    Should I buy a 3.9-5.5 PSI or 6.3-8.1 PSI?
    I am using a VL EFI pump for a 4AGZE running standard boost in a ta22.
    Cheers for the info.
    Pete
    perth
    Default Re: What pre pump for surge tank? 4agze
    im using a carter 72g/hr 5psi lift pump, i dont think it was as expensive as the one you posted.
    you dont need much pressure at all just need flow, you only need to pump fuel to the surge tank. the 5.5 will be fine, just make sure it can move alot of fuel.
    +1 for flow being the important factor here.
    Nov 2010
    tasmania
    while not disagreeing that flow is a major requirment over pressure, surely over doing it with your pre pump can cause a lot of heat in the surge tank fuel? as it would just be continually overfilling and cycling the fuel heating it up? or am i over thinking it?
    also whats the quietist of these kinds of pumps?
    vic
    peirburg no questions , last 200000 klm
    Both the Pierburg pumps above flow a bit over 2L's per minute and that sounds plenty to me. Cheers for the comments.
    My old pump pictured below failed, piece of shit. I had it opened up and the wiring came off the board, these pumps are loud and vibrate heaps. The wire they use internally doesn't stick to solder.
    Had it done properly by one of the technicians at work and then the pump failed shortly after I tested it.
    Also my mate had this same pump and it also died.
    To close the thread, i bought the lower pressure Pierburg pump which flows about 100L per hour which is plenty. Pretty quiet pump and heaps of good reviews.
    Mounting was pretty straight forward with a bit of rubber shielding added on some of the areas that may rub. Also pitted a $10 ryco metal filter cos I reckon tank could have a few goodies in it after 30+ years.
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    i had one like the facet copy pictured above, the dunny door efi pump drained the surge tank at idle in 19 seconds.....
    go for flow !
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    Really? i use one of those Facet copy pumps in my car, (at least I'm think it's a copy, hell maybe it's original) and it's never failed once. I've got a 2L surge tank, and 2x Bosch 044's, running 45 psi fuel pressure. Never failed me once. And beleive me, my engine can empty a fuel tank!!! (How does 110k's to a tank sound!?!)
    Facebook | LinkedIn
    Aug 2010
    country Victoria
    impressive ! hope you are getting good bang for your buck !
    i have a holley " red " im about to try,
    my simple plan to fit a later efi fuel tank with the lift pump was squashed by a very enthusiastic exhaust joint using ALL the space !
    Quote Originally Posted by stradlater View Post
    Yeah thats fair enough, I had a bad experience with the Facet pump pictured so I wouldn't put any trust in them. I'm sure Holley is great as well, I bought the Pierburg after some research and wish I did it right first time instead of screwing around with one second hand pump and the cheapo above
    I am using the carter lift pump, works a treat, i used a facet before hand, it didnt even last a day. :/
    88 gz20 soarer built 1ggte gt30/40 osgiken twin plate j160 gearbox.
    Aug 2010
    country Victoria
    my ( used ) holley red seems to be keeping up but is very noisy , and has some mounting issues
    local parts store wants 350 moneys for a new one !
    im liking the pierburg as it will fit nicely
    best place to buy ??????
    Act
    I run a carter Gold, 4 years no issues
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    I too run a carter - all good here.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
  1. Fuel pump & surge tank Size
    By rogue-vl in forum Tech and Conversions
    Last Post: 22-02-2008, 07:27 PM
