You should be listening to those people. 1 of the best features of any mid engined car is it awesome traction. However, this could be a disadvantage to the car if it is fitted with a 'conventional' LSD. With the Quaife 'anti torque biasing' LSD the wheel with the most traction capacity, the outside wheel, gets sent the majority of the drive. If the LSD simply helps to join the 2 wheels together like a clutch style LSD does, then push under steer under power will more than likely be the case because even in tight corners the inside rear wheel will have reasonable traction capacity and will try and straighten the car when powering out of corners.
