Results 1 to 6 of 6
Thread: High Stall Torque Converters, Lockup and Freeway Revs
    Mar 2009
    Default High Stall Torque Converters, Lockup and Freeway Revs
    Righto!
    So I have had a 3000rpm hi-stall installed, which has been performing very well off the line, however I have noticed that on the freeway at speed my revs have increased a great deal.
    I was under the impression that as long as the lockup clutch was retained, at speed in high gear I wouldnt notice any different, or only a minimal one? Currently sitting between 3600-3900 rpm (over 4 on inclines!) @ 100km/h @ 15% throttle. Before it would sit at about 2500.
    Whats interesting is that at lower speeds, under 80 or so, its no different to before!
    Would this indicate that the lockup clutch is not working, or is this just something I have to live with? Is my stock ECU wondering wtf I have done to the transmission and trying to compensate?
    Default Re: High Stall Torque Converters, Lockup and Freeway Revs
    That does sound like the lockup ain't working? I have a 3000rpm stall in my Aristo and it cruises on the highway around 2500rpm @ 100kph
    Mar 2009
    Well that's actually good to hear, I didn't want to think about fuel consumption driving 40mins of 4000rpm each day to get to and from work.
    Transmission is being replaced so I'll get it looked at then. Hopefully I don't need to get the stall sent back to MV and its just a electrical problem or something.
    Yep, does sound like lockup is not functioning. Could be as simple as wiring to the lockup solenoid, rather than a costly fault with the clutch inside the converter itself
    May 2007
    you might be able to test it by manually rigging up a switch to power the lockup solenoid and see if it changes the revs...
    Mar 2009
    Its going back in to get the transmission swapped on Wednesday, so C-Red can deal with it
  1. Hi stall converters without a trans brake. How to launch?
    By 2JZR31 in forum Tech and Conversions
    Last Post: 30-05-2007, 09:36 PM
  2. Stall converters for the 2J
    Last Post: 31-03-2007, 05:24 AM
  3. Switchable torque converter lockup. What's involved?
    By whatthe? in forum Tech and Conversions
    Last Post: 02-03-2007, 11:06 AM
  4. Stall converters for A340
    Last Post: 03-09-2006, 06:50 PM
  5. A340E Oil pumps/torque converters
    By wiso in forum Tech and Conversions
    Last Post: 07-08-2006, 09:01 AM
