Why didn't you just use the JZZ30 auto transmission complete, it doesn't bolt up?
I'm assuming that you've triple checked the continuity and correctness of the wiring from the 2 wire speed sensor to the JZZ30 engine ECU...
Hmm I also wounder if you get the same code if the SP2 sensor is unplugged...?
It's just the rear extension housing that you've changed right (and the sensor)?, the trigger inside the auto is still the JZZ30 trigger? Does the JZZ30 trigger line up with where the GZ20 extension housing sensor is located?
That should give you a few things to check!
