Results 1 to 4 of 4
Thread: Alternator regulator wiring
    May 2007
    Default Alternator regulator wiring
    Ok so here is the dilemna...
    i am not 100% sure if i have my alternator wiring correct or not... it appears to be charging but im getting some strange voltage conditions... fluctuations and more voltage when running on IG2 than when on IG1... also as the car warms up i lose voltage...
    also my charge light is not turning on at all (not sure if ive blown the bulb at some point...)
    So i am just wondering what would happen should i wire up the L (charge light) wire and the S (voltage sense wire) around the wrong way...
    i have the 3 wire oval plug and from all diagrams ive seen the IG (ignition wire) is in the middle pin of that plug...
    ive looked on wilbos wikki for the wiring pinout but as for which is pin 1 and which is pin 3 could be viewed 2 ways depending on which way you look at the plug...
    so toymods brains trust what do we have?
    Default Re: Alternator regulator wiring
    I've added this to my wiki
    "The following pinouts are viewed looking at the open end of the female pins, or another way to look at is is that the wires connected to the female plugs pictured would exit the rear of your computer screen."
    I suspect the alternator would still charge to some extent, the alternator sense wire would be getting approx battery voltage via the alternator charge light, however the amount of current that the alternator regulator draws down the sense wire is very small and would never turn the charge light on...
    However connecting the charge light pin to where the sense pin goes should blow the fuse for the alternator sense circuit (if you have one ) as it will be shorting battery voltage directly to ground when ever the voltage regulator turns the charge light on.... it's possible that you will have damaged the alternator regulator charge light output...
    Wilbo's JZA80
    Wilbo's JZZ12
    Not sure what vintage wiring you are after, but there's some info on the charging circuits in the Classic Celica Index thread.
    http://www.toymods.org.au/forums/gen...rum-index.html
    Go there and scroll down to the Electrical section and have a squiz.
    seeyuzz
    river
    May 2007
    well looks like as wilbo suggested ive fried the regulator as i swapped a known working one in with correct wiring and the dash lights came on...
    and went off as expected when the car started
    voltage issues if had remained the same so yeah back to the drawing board now
  1. 1jz alternator wiring into s13?
    By ae864age in forum Tech and Conversions
    Last Post: 30-05-2010, 03:15 PM
  2. RA60 21R-C wiring diagram - Voltage Regulator
    By TTCorona in forum Tech and Conversions
    Last Post: 16-05-2010, 04:13 PM
  3. alternator wiring????
    Last Post: 22-10-2007, 03:08 PM
  4. gen 2 3S-GTE Alternator wiring
    By ONCE-NA in forum Tech and Conversions
    Last Post: 20-08-2007, 06:53 PM
  5. Alternator or Regulator stuffed?
    Last Post: 17-12-2005, 11:20 AM
