Results 16 to 30 of 45
Thread: ae71 panel van with V-TEC... YO
    Mar 2011
    Default Re: ae71 panel van with V-TEC... YO
    Lol. Tell ur frenz haha
    Mar 2011
    Great choice of engine!!
    SHEPPO..
    Mar 2011
    finally the parts that got lost in the mail hav been replaced and now i hav them. lets hope the honda motor is as good as i was told
    victoria
    i think i just jizzed in my pants
    4+4=8
    4 cylinders + 4 throttles = V8 like noise
    Mar 2011
    almost hav the engine out of the s2000. is alot harder then it looks. ive spent like 7 hours trying already and finnaly hav it to the point where its floating in the breeze. but cant pull it out the top cause it hits on the reo bar and cant drop it out the bottom with completly removing the sub frame. but since i dont want to grind anything off so i can still sell the shell ill hav to drop the subframe down and bolt it back up so it can roll agen
    Mar 2011
    engine out of the panel van
    enigne out of the s2000
    chilling out, waiting to be worked on
    Mar 2011
    so didnt get to work on it for like over a month but last couple weekend ive made some progress. i wont post up all the pics cause that will take ages, but i fitted the motor while lowereing the crossmember 2 inces so i didnt hav to cut outthing out besides the crossmemebr itself. but i didnt like lowering it that much so i cut the tunnel out and now its only lowered 1 inch and the bonnet just clears by about 5 or so millimeters.
    so i had to cut the crossmember up to clear the sump, cut out way to much so will do another one later down the track
    made mounts out of 2 left hand engine brackets from a 4a and standard 4a rubber mounts
    took a while to work out where the center was but i found it eventually
    Mar 2011
    as i sed before i cut the tunnel out so i didnt hav to lower it so much
    ended up cutting it all the way back so i could het the shifter in a level position
    still looks awesome
    Mar 2011
    had double that clearance before i raised the crossmember back up a touch
    thats pretty much eveything up to date, next thing on the list is to make a gearbox crossmember
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    nice work this is a real unique conversion cant wait to see a video when its done to hear the noice out of the ae wagon
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Mar 2011
    cheers man. i want to make 2 exhausts for this. one for the street and one for the track that exits infront of the rear wheel with no mufflers so its stupid loud lol
    Underpowered Backyard Mechanic Moppitt's Avatar
    Seeing how tight it is for space, its definitely a good thing you didn't go for the K24 then. They are something like 20mm taller in the block and thats space you really dont have...
    Great to see the progress!
    Feeling down? See: Beyondblue or for youth see: Headspace or call Lifeline on 13 11 14
    Finally, a members ride thread. I present project One Thing Lead to Another (nominations for a better name are now open)
    Rabble, rabble rabble!!
    Apr 2007
    wilcannia NSW
    sweet conversion. are you going to close up the crossmember where you cut it ? if you plate over the holes it will give it some strength back.
    Mar 2011
    yeah gunna weld it all up to look nice. im goin to do another one tho, one that isnt cut back so much and neater mounts. but this will do for now.
    havnt done anything since i cut the tunnel. next on the list tho is to make a gearbox crossmember
    May 2007
    victoria
    Just read the thread and was thinking the same thing.
    I hope he's gonna box up ad gusut the k frame
  1. 4AGZE into AE71 Panel Van
    By De@No in forum Tech and Conversions
    Last Post: 06-06-2006, 07:56 PM
