Results 1 to 8 of 8
Thread: 4AGE RWD Alternator Information
    Dec 2010
    New south wales
    Default 4AGE RWD Alternator Information
    G'day,
    Looking under hood while trying to turn my Celica over last night I noticed sparks from where the main power termianl goes into the alternator. So I thought I'll just tighten that up. I start to tighten the nut and the stud completly snaps clean of the back. I was only using my hands to tighten it.
    So to cut along story short how hard is it to replace that stud or is it easier to just get a new alternator in the short term?
    And if a new alternator is easier is there much difference in types, could I use a FWD or something?
    Do it once, do it right.
    "Daily" 1975 Celica 2T-g ----->4AGE
    Car that scares the hell out of me 1994 300ZX TT
    Default Re: 4AGE RWD Alternator Information
    I have a busted alternator laying around, if it's easy enough to pull out I can mail it to you for next to for very little
    Jun 2006
    You can use one from a 20v motor you just have to use the 20v plug and and wire it as follows.
    white to white
    black to red/blue
    blue to yellow
    Dec 2010
    New south wales
    Can I use one out of a 16V from a FWD drive?
    There are a bit more common that a 20V
    same mounting, might have a different plug but thats about it
    Dec 2010
    New south wales
    Will have to have a trip down to the wreckers then and see what they have.
    Shouldn't be to hard to mod the plug on the back. Well I hope not anyway
    resolder 3 wires, just make sure you bunch them together later on to help avoid fatigue. Plugs are also available new from auto elec's
    Dec 2010
    New south wales
    Well that will make things a bit easier. I will hopefully get around to doing this tomorrow.
    I got stuck two days ago when the wire from the broken stud came off again and the battery died not long after. Had to do some dodgy on the side of the road soldering with a lighter just to get home.
  1. 4ac Alternator onto 4AGE
    By sirsprinter in forum Tech and Conversions
    Last Post: 04-12-2008, 02:07 PM
  2. 4AGE 100kw alternator vs JDM AE86 alternator vs AE86 4AC alt.
    By xolent in forum Tech and Conversions
    Last Post: 09-08-2006, 10:42 AM
