Results 1 to 15 of 19
Thread: Blower Resistor
    Jul 2008
    NZ
    Default Blower Resistor
    I need blower resistor for my AE92 FXGT (it has auto air) and am having trouble tracking 1 down. All the ones I've sourced, so far, have also been broken.
    Does anyone know if a AE101, or another rolla, model will fit?
    Default Re: Blower Resistor
    Isn't it just a big fuck off resistor? If you know what it's resistance should be and its wattage, then you can buy one at Jaycar. Matter of fact, buy one with a bigger wattage (assuming it will fit) and it won't blow/break again. Of course, I'm assuming it's not some wierd shape or anything like that.
    seeyuzz
    river
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    hi i bought a 5 ohm and a 2 ohm from jay car and soldered them in .plenty of room and im happy with the fan speeds
    cost less than 5 bucks
    cheers !
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    seeyuzz
    river
    Most of them are wire..
    I.e. image stolen from the internet
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    NZ
    That's it Wilbo.
    Do you know what wire to use to make the coil?
    i just found where the break in the coil was, removed the shortest section, stretched the coil out, and soldered the new leg to where the old one was.
    Done this on 2 or 3 cars now, worked a treat.
    Jul 2008
    NZ
    Unfortunately, the 2 coils that have broken are in such a bad way I'm not going to be able to do that CrUZida. Good idea though.
    I either need to solder in new coils or replace the whole thing. At the moment I only have full fan speed.
    Jul 2008
    NZ
    I have some stainless safety tie wire - will that work?
    I could easily coil it round a pencil or pen and solder the ends to the terminals (if stainless solders?) and make the coils different lengths for the different speeds needed.
    Thoughts please?
    You can buy them brand new.
    Get the part number from toyodiy.com and hit up amayama.
    Aug 2010
    country Victoria
    i ended up at jaycar after trying to solder mine was doing a great job till i touched the wire coil and dropped the lot ! ( TWO owies ! )
    Quote Originally Posted by ke25_rolla View Post
    That's it Wilbo.
    Nichrome wire is what is usually used.
    i.e. this might be worth a try P
    Nichrome Resistance Wire - 4 metre pack - Jaycar Electronics
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    NZ
    Cheers Wilbo.
    I'll pop into Jaycar and get some of that nichrome wire.
    Jul 2008
    NZ
    Got some of that nichrome resistor wire today (0.32mmX4m $5.90) from Jaycar, so will have plenty to trial a few coils to see what works best.
    Will update later on how it went.
    Jul 2008
    NZ
    Well I made a coil and soldered it in to see if it would work. Nope
    I only have the fastest fan speed still.
    Bummer!
    Do you have a multimeter?
    Youll need to test what the voltage drop is across the nichrome resistor youve made.
    You wont be able to just copy the factory size and num of loops as the wire properties will be different. You also might have to run two runs of wire in parallel as the nichrome from jaycar might be too thin and end up red hot or melting.
  1. Blower resistor smoking
    By Camryman in forum Tech and Conversions
    Last Post: 23-11-2009, 05:40 PM
  2. A new Blower... or same old, same old
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 28-01-2008, 12:56 PM
