Originally Posted by
Shane~182
Once I do these II1 and IJ1 wiring, will the car start? or am I also suppose to wire up the (B) ecu plug to the 5m-e harness
which would be these 4 wires.
Terminal 1 is ignition switch power
Terminal 24 gets wired to pin 8 on the 8 pin under the bonnet. (main relay coil) or is it wired back through the ecu and can be left out?
Terminal 31 and 32 are also for the EFI main relay, so, do they need to be wired up the 8 pin plug aswell? as it says on the diagram (Needs battery voltage, so id assume so.. right?)
Terminal 33 is BATT, and needs to be wired to constant?
