Did you machine your flywheel before install?
If not then I would say your flywheel has a warp which is creatig a burr in your clutch disc. Either way it will stop and should be fine.
I just recently replaced my clutch with a new exedy organic around 1000km ago (havent trashed it yet),
I can smell burnt clutch when releasing it normally, worse when reversing.
I know this is not normal because it's burning before it even bites.... also got other people to drove it and its doing the same thing (so its not my driving)
One thing i also notice the biting point also getting further away then it was originaly.
any ideas?
You could have also dropped your pressure plate making that the issue.
I did this once and had a 1k clutch last 5000kms without warranty. Was also a kent to use while it lasted.
