Results 1 to 5 of 5
Thread: w58 burnt gears please help
    vic
    Default w58 burnt gears please help
    Gday guys we pulled my w58 apart and found that 3rd and 4th gear are burnt.
    Obviously someone has run low on oil!
    I haven't had this box in my car yet, is it worth running it for a while or will it
    destruct pretty quick?
    I know gearsets are worth heaps, any ideas to get out of this problem?
    Anyone got 3rd and 4th they want to sell?
    Default Re: w58 burnt gears please help
    as in discoloured... like blue or black?
    the heating, depeding how long, could have caused the surface hardening to be... not so hard....
    meh, if you don't have another box yet... may as well run it
    it might blow up but..... it should make noise first.
    umm.. and take vids of when it does but yeah, find another gearset/box
    if you've munted the gear set on the input or output shaft, the layshaft (also called the counter shaft) is going to be just as stuffed.
    You've be better off finding a replacement box at the wreckers and posting pics of the damage you did.
    cheers,
    Charles.
    Junior Member Backyard Mechanic 1jzracing's Avatar
    ive got as couple sets of gears in perfect condition but only the ones on the main shaft no lay shaft
    ***CHECK!!*** the main shaft where 3rd gear runs as toyota in all there wisdom failed to put a needle roller on this gear so it has a habit of picking up the shaft and chewing on it - especially if oiling has been an issue, the later boxes have twin syncro's on 2nd and a bearing under 3rd gear
    if they are only coloured and not scuffed they should be ok, sounds like low or the wrong oil for sure
    if you want my ones just to be a bit safer let me know ... pm sent
    How much does a w58 demand these days?
    Facebook | LinkedIn
  1. W50 vs W58 - need info to do the swap on my RA28
    Last Post: 13-04-2014, 08:53 AM
  2. W58 stuff
    By Big rob in forum Tech and Conversions
    Last Post: 27-01-2008, 07:43 PM
  3. Clutch Slave Cylinders (W58)
    By e30-323ti in forum Tech and Conversions
    Last Post: 12-01-2006, 10:36 PM
  4. W58 Supra gearbox Input spline count info
    By Esteban in forum Tech and Conversions
    Last Post: 29-12-2005, 12:11 AM
