Results 1 to 4 of 4
Thread: mx83 electrical problems!
    May 2009
    south australia
    Thumbs down mx83 electrical problems!
    Hey there guys just having a huge dilemma here at the moment!
    I purchased a cressida off some guy a while back the car had been in a bingle i have spent the past few months straightening the front up ect.
    Now i have been around the car checking everything and had it running,now with it idling at 1000 rpm with the radio on after a while it kills the battery and the car turns itself off,or i turn it off.
    I have just been checking globes ect and the d/s outter taillight globe was blown so i removed the taillight changed the globe and then had no tail lights,discover a blown fuse replaced that and still nothing!
    If anyone has had this problem before or has a clue it would be greatfully helpful.
    Thanks for looking matt
    Oct 2008
    TAS
    Default Re: mx83 electrical problems!
    is the alternator charging ok ?
    1983 Toyota Celica Supra
    May 2009
    south australia
    yeah seems to be if something is turned on the rpm goes up the battery seems to be fried now also so maybe thats the problem!
    May 2006
    tas
    the park lights and dash lights are on the same circuit. i short circuited something when i was wiring a gauge in mine, havent tracked it down yet ive checked all fuses not sure where the issue lays.
    also there should probably be a electrical load sensor, so when you have other electronics on they may increase the idel so the alternator can keep up. to get a better idea of your battery and alternator health grab a multi meter from bunnings or where ever, switch it to voltage and test the voltage across the terminals with the engine off, if its below 12.5v its either not holding charge or something it drawing current. with it running you should see higher voltage maybe around 13.5-14v (can someone confirm this?)
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  1. Can exhaust welding cause electrical problems?
    By Z2TT in forum Tech and Conversions
    Last Post: 21-02-2010, 05:31 AM
  2. Electrical problems-Tacho
    By woggin in forum Tech and Conversions
    Last Post: 28-01-2009, 06:19 AM
  3. Ra28 electrical problems, alternator?
    By shewiththe18RG in forum Tech and Conversions
    Last Post: 05-06-2007, 10:23 AM
  4. Electrical Problems - 20v
    By Escy in forum Tech and Conversions
    Last Post: 15-01-2007, 02:50 AM
  5. hilux electrical problems.
    By rn-85 in forum Tech and Conversions
    Last Post: 15-03-2006, 09:22 PM
