Results 1 to 2 of 2
Thread: ECU plug help
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default ECU plug help
    I'v got a 1uz vvti ecu which is missing a few plugs. Can anyone identify which other toyotas they are used in. I know jzs160/161 use the same plugs. But i'm trying to find something more common. See in the pic for the missing plugs.
    1994 GZX90 Mark II 1GZ-FE V12
    Default Re: ECU plug help
    ZZE Corolla (03-05) are the same I've been told.
    Also here are the part numbers so you can order them from Toyota (I used these part number when I wired up my factory 2JZGTE VVTi engine ECU.. you would have been able to read these off your JZS161 engine ECU )
    Connector 28 Pin Female: Toyota 90980–11637
    Connector 22 Pin Female: Toyota 90980–11638
    I think there were ~$7ea. I had some other plugs (2JZGE VVTi I think) that I salvaged pins from...
    Wilbo's JZA80
    Wilbo's JZZ12
  1. Looking for a headlight globe plug, So I can plug into the stock socket.
    By TERRA Operative in forum Tech and Conversions
    Last Post: 26-11-2008, 07:31 AM
