Results 1 to 8 of 8
Thread: 4age oil cooler pressure relief
    Jun 2006
    Default 4age oil cooler pressure relief
    Just seeing if anyone know the pressure that a stock 4age oil cooler pressure relief valve opens? Can't seem to find it anywhere
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    Default Re: 4age oil cooler pressure relief
    70psi is the normal relief.
    Now 9AGTE 410kw atw
    oregon
    Here is the oil pump pressure relief...
    Jul 2007
    is that the oil pump change between the bigport and smallport 4AG or whatever the series were?
    oregon
    not sure WHEN the change occured, but if you use the 19036 pump you'll be using the newest
    Those pumps above are both big port pumps. Small port pumps have a lot more sharper teeth.
    oregon
    Quote Originally Posted by Ken_T View Post
    small port pump
    for complete oil pump info - http://www.hachiroku.net/forums/showthread.php?t=15957
    I see. I was going off this. Which I see in that thread to be backwards.
  1. 7MGTE Oil cooler relief valve question
    Last Post: 21-07-2010, 02:51 PM
  2. Cooling System Header Tank and Pressure Relief Point
    By Duk in forum Tech and Conversions
    Last Post: 13-04-2010, 04:47 PM
  3. 3sgte oil pressure relief
    By af300e in forum Tech and Conversions
    Last Post: 03-04-2008, 03:42 PM
  4. oil cooler+4age
    Last Post: 04-04-2006, 04:01 PM
