Results 1 to 15 of 24
Thread: 3SGE in RA65
    Jun 2011
    Default 3SGE in RA65
    Hi all
    This is my first time so bear with me
    I am building a club level? rally car on a budget. If you are married with kids you know what i mean. It is a RA65
    So far i have fitted a MX73 rear end complete and now have a 3SGE BEAMS and 6 speed (from Altezza front cut) hanging off the chain block
    I bought a complete front end from a SA63 which had been converted to take S13 coilovers and has P/S rack
    Problems i have found so far are
    1/ the sway bar will hit sump
    2/ the steering shaft is too long (have shorter one)
    anyone got any ideas so far
    Jun 2011
    Default Re: 3SGE in RA65
    just found that the 2S engine mounts from ST141 are too wide (long) and dont match up with crossmember. help please
    anyone got a SA63 crossmember?
    Have a look in the members rides threads, there is a recent thread with a 3SGE into RA65.
    And yes, you'll need an SA63 crossmember.
    if you can't find a suitable cross member I've got a handful of comparison pics between RA65 & SA63 cross member that might assist in shifting and modifying the mount platforms on the cross member.
    I note in your original post that you say you've got a 'complete front end from a SA63' - is that cross-member no good?
    I'm using the engine mounts from an ex-SA63 2S motor if you'd like some reference pics.
    Jun 2011
    yeh sorry wasn't very clear what i said
    the front end did come from a SA63 but was running 18RG
    thought i was in luck till i tried to fit it then measured it up
    xmember comparison pics would be gr8 thanks
    Jun 2011
    up to doing the exhaust stage
    shop guy says 2 1/4 but i think 2 1/2 as long as not too loud
    front cut didnt come with engine pipe so looks like will need to customise
    does anyone know of a Altezza engine pipe laying around not being used
    What turbo is it running? I've got a custom built 3" dump pipe to suit a CT26 (low mount) in an SA63....
    Only problem maybe is the way we positioned the turbo in my car may very well not match yours....
    Jun 2011
    non turbo - N/A
    looking for the OEM engine pipe if possible
    Oh right, yeah, would you look at that "3s GE in ra65"
    Sorry about that.... Suffering mondayistis on a Tuesday!!!
    duro: what front swaybar did you end up going with? Just curious as to how you got the clearance to the sump that you said you needed.
    Jun 2011
    no sway bar as yet. gunna try without one first
    fwiw: I was going to run no sway bar on the rear of my rally barge (link in sig) but keep a bar at the front. Will be interested to see how you find the front behave with no bar (personally, I think trailing throttle & cornering & no front bar will equate to way-too-much understeer, but I'll be a slightly heavier car with a boat anchor for an engine).
    Melbourne Victoria
    with block and sump in ,i used a coat hanger and bent it to go around sump then taped it to sway bar and got white line to make custom 1 up for my ra series celica
    and i use 3 inch mandrel exhaust system for my beams
    Jun 2011
    any decent exhaust guy could do the 2 1/2 that i think i'll go with
    thats not the issue
    some half cuts come with half the exhaust unfortunately mine stops at the flange
    thats why i need the engine pipe otherwise will have to tailor it
    Jun 2011
    exhaust is done. got a flange plate made up for $50
    engine is now running but only making 114hp at wheels on dyno
    is running too lean and of course thats not easy to fix with original ecu
    think it might have something to do with Greddy AFM and pod
    from what i read the 3SGE's like the factory gear with factory ecu
    any ideas anyone or know where i can get Altezza AFM and airbox
  1. 3SGE BEAMS into RA65 celica.
    By sumfancyname in forum Tech and Conversions
    Last Post: 05-06-2021, 08:17 AM
  2. Replies: 0
    Last Post: 06-05-2010, 11:45 AM
