Results 1 to 12 of 12
Thread: Fuel Level Sender Ohmages (AE86 specifically)
    Default Fuel Level Sender Ohmages (AE86 specifically)
    Alright, since my in dash gauge doesnt want to work properly when removed from the dash and ziptied to the boot (could have been because i smacked it with a spanner by accident) im going to need a new enclosed gauge.
    However, i have no idea of the ohmage of the Toyota senders, and Google simply turns up thousands of links of people selling crap. Anyone know the specs?
    Default Re: Fuel Level Sender Ohmages (AE86 specifically)
    Test and measure....well at least that's what i plan to do with my RA28 fuel level sender - cos i'll be using an old Jaycar digital measurement display kit as my fuel guage....
    ...... butt scratcher?!
    Yeah, i was hoping someone has already done it. Ill have a fiddle tonight.
    I'd be interested to know the results of this if you do
    someone has replaced mine with with a non stock item and the scale of the fuel guage is crap now (reads 3/4 when tank is actually full)... will probably replace it with something when I fit an intank pump
    Junior Member Backyard Mechanic Sigmeister's Avatar
    Double post...Sorry
    Classic JC Quotes
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
    "Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
    "The Mitsubishi 3000GT is about as sporty as a game of Darts."
    Takai,
    Try calling Gauge Works (08) 8445 6644. They should be able to look in the book and tell you over the phone.
    Classic JC Quotes
    Thanks Siggmeister, from what they said it goes as follows:
    F: 3ohm
    1/2: 33ohm
    E: 110ohm
    Ill test that tonight as i have maybe 1/4 of a tank in there, and ill see what reading i get.
    +rep for you.
    south australia
    here is a test that you can do to see if the actual gauge on teh dash is ok....
    and it looks like gauge works is correct.....really close actually!
    http://toymods.org.au/Repository/Tec...scanned_25.jpg
    ^^ Hey that is great slide86, I can now go and check the resistances of my sender and also that the arm is bent to the correct height.
    The old adage holds true once again -> RTFM
    Don't know whether to pos rep you since your rep suits your name so nicely
    Rob
    south australia
    i know. ill screen capture it for sure!
    Junior Member Backyard Mechanic gixer's Avatar
    Takai, shame your not racing on the 20th I was waiting to see your lap times!
    Yeah, im sad about it too. Actually im quite pissed off about it.
    Suspect the ECU is falsly earthing the PCB through the chassis of the box.
    Ill post more in the Members Rides thread i have.
  1. Replies: 1
