Test and measure....well at least that's what i plan to do with my RA28 fuel level sender - cos i'll be using an old Jaycar digital measurement display kit as my fuel guage....
Alright, since my in dash gauge doesnt want to work properly when removed from the dash and ziptied to the boot (could have been because i smacked it with a spanner by accident) im going to need a new enclosed gauge.
However, i have no idea of the ohmage of the Toyota senders, and Google simply turns up thousands of links of people selling crap. Anyone know the specs?
Yeah, i was hoping someone has already done it. Ill have a fiddle tonight.
I'd be interested to know the results of this if you do
someone has replaced mine with with a non stock item and the scale of the fuel guage is crap now (reads 3/4 when tank is actually full)... will probably replace it with something when I fit an intank pump
Double post...Sorry
Classic JC Quotes
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
"Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
"The Mitsubishi 3000GT is about as sporty as a game of Darts."
Takai,
Try calling Gauge Works (08) 8445 6644. They should be able to look in the book and tell you over the phone.
Classic JC Quotes
Thanks Siggmeister, from what they said it goes as follows:
F: 3ohm
1/2: 33ohm
E: 110ohm
Ill test that tonight as i have maybe 1/4 of a tank in there, and ill see what reading i get.
+rep for you.
here is a test that you can do to see if the actual gauge on teh dash is ok....
and it looks like gauge works is correct.....really close actually!
http://toymods.org.au/Repository/Tec...scanned_25.jpg
Originally Posted by The Witzl
^^ Hey that is great slide86, I can now go and check the resistances of my sender and also that the arm is bent to the correct height.
The old adage holds true once again -> RTFM
Don't know whether to pos rep you since your rep suits your name so nicely
Rob
i know. ill screen capture it for sure!
Takai, shame your not racing on the 20th I was waiting to see your lap times!
Yeah, im sad about it too. Actually im quite pissed off about it.
Suspect the ECU is falsly earthing the PCB through the chassis of the box.
Ill post more in the Members Rides thread i have.
