Results 1 to 5 of 5
Thread: MZ20 brake master cylinder
    Junior Member Grease Monkey Bored?'s Avatar
    Default MZ20 brake master cylinder
    My soarer's master cylinder seems to be on its way out, so...
    Are MA70 master cylinders easy to get?
    Is an MA70 master cylinder going to be identical to an MZ20 one?
    Are master cylinders identical regardless of whether or not a ABS is fitted?
    Default Re: MZ20 brake master cylinder
    whats wrong with it ? is it jsut requiring a rebuild ? bad piston seals / pitted bore ?
    consider getting a stainless steel sleeve and a rebuild kit though it. saves chancing it on another 20yr old unit.
    Feels like the seals are probably going, though I'm still driving around with it at the moment.
    I was hoping that it would be possible to buy a new replacement instead of re-sleeving the old one. If not, then I guess a rebuild is on the cards.
    Someone must know the answer to this, or have access to the toyota part numbers in order to check.
    Or please, if you know where I can find the part numbers, let me know! So far I've only been able to find the part numbers on US MA70, but no one knows anything about MZ20.
    BHGBTDT Domestic Engineer kemicalx's Avatar
    An ma70 master cylinder rebuild kit will work with your z20, also there is a difference between the abs and non abs units.
    By The Witzl in forum FAQ
  2. Brake booster and master cylinder KE30
    By shy_77c in forum Tech and Conversions
    Last Post: 31-05-2006, 06:18 PM
  3. JDM Master cylinder size
    By toddw in forum Tech and Conversions
    Last Post: 29-03-2006, 03:06 AM
  4. Need bigger brake master cylinder on KE70
    By crostek in forum Tech and Conversions
    Last Post: 09-02-2006, 07:12 PM
