Results 1 to 3 of 3
Thread: A340E and A341LE Valve bodies?
    Apr 2009
    Default A340E and A341LE Valve bodies?
    Hey guys, just a quick question... can anyone tell me if these two boxes (7mge cressida and 1jz jzx81) share the same valve body? Looking at using a 7m valve body in my 1j gearbox and as far as ive been able to find out theyre the same but can anyone confirm?
    Cheers, Jason.
    Default Re: A340E and A341LE Valve bodies?
    I would not expect the valve bodies to be the same but you can swap one for the other . Another thing to consider is the a341 has a taller first gear than the a340
    Jealousy is a curse
    I used an a340 valve body in a a341 box, I can't remember the end numbers. I had an a340 from a jza70 and when I stuffed up the oil pump I could only find a soarer a341 tranny to replace it. as my a340 had a shift kit mod done to it I didn't want to lose it. When I swapped over I had to swap the boxes wiring loom with the valve body as I think the 341 had an extra wire to the valve body??? that the 340 didn't.
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
  1. A341LE & A340LE valve bodies differances, help?
    By wiso in forum Tech and Conversions
    Last Post: 04-09-2006, 10:34 AM
