Results 16 to 24 of 24
Thread: 3S-GTE guru needed!
    Default Re: 3S-GTE guru needed!
    Facts : Oil completely pissed out of engine, grub screw is missing from a pressurised oilway.
    Just go with what is *most* likely to have caused the leak, fix it, and most of the time you'll be right. If you have to pull the engine out again, at least it's only bad luck - rather than bad methodology.
    being grub screws and parallel thread, they will not have torque settings?
    is loctite suitable for oil/petrol solvents? or do you need some of that white fuel sealing loctite goo (number 567??)
    oh - forgot to add that Stu is correct here - Loctite 567 (Master Thread Sealant) is the absolute best shit you can use!! It's designed to work at something spastic like 10,000psi and is resistant to petro-chemicals (ie, petrol, oil, and other nasties found in yer engine).
    Melbourne Victoria
    i just put some toyota black packing material on the threads that works as they use that on the sump etc ,sometimes we even use it on a old steel gasket as well
    Ahh well looks like engine back out tonight.. Best to be safe hey.
    Thanks all for the comments.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Melbourne Victoria
    just remember do it once ,but do it properly and take no short cuts ,you have had it in and out for the last 8months another couple of days wont hurt
    That Toyota black "sump-goo" as i call it is actually another LocTite product! I'm just yet to figure out which one....
    Well I hoisted out the engine last night, pulled the sump off, timing gear, oil pump and found the nasty hole.
    Grub screw is back in.. Picked up new oil pump gasket this morning from Toyota.. Hopefully be back together tomorrow night.
    Joel
    Good luck with it this time mate.
    TRIKKE | Video
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    good luck mate, keen to hear how it goes!
    trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
  1. 5S FE to 3S GE
    By adam golder in forum Tech and Conversions
    Last Post: 05-10-2007, 09:47 PM
  2. Modifying the Beams 3S
    By admin in forum Tech and Conversions
    Last Post: 26-12-2005, 08:57 AM
