Originally Posted by
3sgte
That is the question that stopped me from doing the head swap. At the time, I was looking for a no brainer displacement bump, I even had a set of stock later gen 20 mm floating pin type 4AG pistons off a 91 AE92. Decided I would wait for the money to have some custom pistons made (bought an ST165 instead).
Given the lack of oil squirters, I wasn't sure if there would be adequate pin lubrication in the bottom of the piston.
If one were to bore the small end out for a bush, would there be enough meat left there to run at 7000 RPM?
If people are claiming "weak rods", or have rods that failed, is this just because they are running a floating pin in a rod designed for a press fit (or a press fit pin in a 'floating type' piston)? In other words, a pin that doesn't have the lubrication or clearance it was designed for?
Pin sizing is typically very precise, I would expect that as a sticky point for doing a mix and match job with the pistons/rods as I had originally anticipated.
This isn't to point fingers, this is just a 'devils advocate' kind of thinking. I mean, if the failures are all "big end" failures, then I guess it hardly matters.
I would have only felt comfortable winding the motor out with aftermarket pistons (due to pin concerns).
Also, the big end bolts are plastic region type bolts. This means that the bolts are actually stretched as the 90degree final step is performed. Running at 7000-8000 RPM, I would want a new set of bolts each time.
If anyone has experienced big end failures, I am all ears. Did the bolt break, or the threads pull out of the rod?
