Results 16 to 22 of 22
Thread: rebuilding a ball bearing turbo
    Aug 2009
    Default Re: rebuilding a ball bearing turbo
    so did you have to press it apart?
    Jul 2008
    Auckland
    We have a guy in NZ who can rebuild the Garrett BB units for under $1kNZD.
    He has developed his own ceramic ball bearings to replace the original ones.
    ALOT of the Motorsport guys use him over here and they have proven to be super reliable, more reliable than the garrett ones!
    Now 9AGTE 410kw atw
    Low rep Grease Monkey
    Apr 2010
    bkk
    wow good luck
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    still going, touch wood
    bazda - who is the guy in NZ who rebuilds the garretts? I've melted the exhaust blades, so if it's a reasonable price I could justify posting it
    Perth
    Had a couple of people pm me lately asking for advise.
    If anyone has any questions, ask in here and I will try and remember how I did it.
    Quote Originally Posted by beatle
    Quote Originally Posted by nisspug
    Hi Beatle,
    I plan on rebuilding my BB GT2871 Garrett turbo soon and after seeing your old thread on rebuilding your BB turbo was wondering if you'd mind answering a few questions.
    1. how did you end up getting the shaft out of the CHRA?
    2. how did you get the bearing cartridge out of the CHRA? Is there a circlip holding it in or a locating pin in the oil supply hole? How do you get this pin out? Does the cartridge then just slip out?
    3. how did you reassemble the balls back into the bearing cartrige?
    any other tips you have would be greatly appreciated. I plan on using one of the Chinese ceramic BB cartridges on ebay or maybe just replacing the steel balls if I can buy them and the bearing race is in good condition. Thanks
    regards, Andrew
    Happy to help Andrew,
    the shaft and bearing assembly come out all together. First you need to remove the inducer wheel, which is left hand thread. in the GT3582R their is a locking pin integrated into oil feed fiting that screws into the CHRA, from memory is should come out with a hex key. the shaft and bearing assembly should just slide out of the CHRA. but it was a while ago and i may have forgotten a step or 2.
    To get the bearing assembly off the shaft, I used a Toledo long jaw puller and pulled it straight off the shaft, with a bit of lubricant sprayed and the shaft where it was sliding across
    To get the balls back in the race, I used some grease to hold them with the cage on the inner race then hand pushed the inner and outter races back together.
    3 years on and its still going strong.
    May I ask why you are rebuilding it?
    Regards,
    Mike Beatle
    Perth
    Thread update,
    It is now getting a bit noisy. Have done around 20,000kms give or take 5,000ish.
    Looking at doing it again with the 'mamba' bearings and turbine shaft. Although the price of the genuine Garrett CHRA has come down significantly, it's still around 1/3 the price.
  1. F LSD diff noise pinion or bearing? rebuilding
    By naten in forum Tech and Conversions
    Last Post: 04-03-2009, 10:00 AM
