Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: F series Torsen options
    Default Re: F series Torsen options
    Altezza/IS200 hemisphere certainly does work in live axle F-series, no doubt, as mr75 said. I had one in my car for some time, loved it (over the previous clutch pack LSD) and never had a drama with open wheeling for drags, circuit, or khana work.
    If you're using an F series housing from a Corona however, please please please make sure you adequately baffle it to keep oil from running up the axle tubes on long bends, if you haven't done so already. You have been warned
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    1jzrolla what diff centre did you use? is200 are torsen yes?
    heres some pics of said baffles
    diff without baffles
    diff with baffles
    yep that's the one
    Pffft, live axle I'm looking to put it in an MA61 housing
    Mar 2009
    Auckland
    Hahah I have pm'd you mullett. Could have something in the works today if you reply fast
    Quote Originally Posted by mullett View Post
    oh In that case, make sure you measure the engagement of the half-shaft splines when you assemble it, just to be sure There can be some oddities between toyota LSD's between axle/housing combinations.
    Oct 2008
    TAS
    The After market diffs often won't have the groove in the side gear for the circlip either.
  8. #38
    Well, just ordered a diff from MR75...should be awesome!
    -RM
  9. #39
    May 2007
    tasmania
    and youll sell me you ma61 lsd yes?
  10. #40
    May 2006
    tas
    TBH, I've got a tight clutch-style LSD at the moment, and I feel that it makes the car understeery on corner entry, pushes the front around...
    it maybe a 2way? a 1 or 1.5way would be superior for grip driving. i had a 2way in my s13 a brand new KAZZ i never had any understeer from the lsd pushing. granted it was a drift car but i had average tyres on the front.
    FYI i believe the live axle centres do not have a grove for a clip that holds the axles in on IRS cars.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  11. #41
    It's a standard MA61 diff, rebuilt with a maxxgrip centre:new springs, more plates and much higher breakout force
