Results 1 to 6 of 6
Thread: 2wd surf
    Jan 2008
    queensland
    Default 2wd surf
    hi all
    having thoughts of building a 2wd surf?
    long term project
    anybody ever done one?
    i know i will have to cut a hilux chassis and shorten it 210mm
    unless anyone has any better suggestions.
    the modplater i normally use told me i can lengthen a chassis but not shorten it
    sounds silly to me (i can put two weld beads in it but not one)!
    but he is happy if it is neat will still give me a rwc if i dont tell him i did this.
    the joy of having 4-5 rwc's with him every week and being easy to get along with
    body mounts will have to be moved.
    1uz auto conversion.
    any other problems that will pop up?
    thanks all for your thoughts
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Apr 2011
    vic
    Default Re: 2wd surf
    Why change chassies ? There isnt alot of difference from a surf to a lux chassie in the front end from the quick looks I've had. I bet its all the same (frame rails etc) asside of the bolt on bits I know independant front end 2wd highluxes have been changed to 4wd leaf sprung axle here in shep. Prob alot easyer to strip the surf chassie front end and bolt/weld etc a highlux front suspention bits on. And I assume yout going down in hight so suspention mods would have to be done to a highlux front end anyhow if your going down much.
    Short wheel base hilux chassis is the right length, not the easiest things to come by though. You'd just need to move the rear body mounts.
    Or
    I've got a mate back home that's done a 2wd surf, there's an easy way. But you'd need both chassises. Cut along the factory weld line in front of the gearbox crossmember on both chassises then weld them together. Plate and weld. Swap over rear leaf spring mounts. I'm pretty sure the 4wd chassis is completely different in front, I'll check and get back to you.
    You'll probably get more info on a site like downundertruckin, there's a few surf swaps on there. Or minitruckin.co.nz
    I'll try and dig up a couple of links
    Found a whole bunch, but lost the post. Heres a pretty over the top one on DUT, search for Big Matts one on there too. Its static and has got some good how to pics.
    http://www.downundertruckin.com/foru...surf&start=225
    Jan 2008
    queensland
    rxtoy - tried to register on the forum but would not acccept any answers to the question about what the forum was about?
    any clues?
    neil
    2009 aurion
    Minitrucks? Minitruckin? Something like that.
  1. 2jz-ge Surf
    By nilprospects in forum Tech and Conversions
    Last Post: 10-04-2012, 03:38 PM
