Results 1 to 15 of 23
Thread: The Beams is in my Celica, but I can't get it to start
    Mar 2010
    Default The Beams is in my Celica, but I can't get it to start
    Hi all,
    I've just finished installing a 3SGE Beams in my ST204 Celica, but I can't get the bugger to fire.
    The engine came from an ST202 Celica (same shape) so I've swapped over the interior looms as well, but still no go.
    Basically the engine will turn over, but just won't fire. Initially we thought the fuel pump was the issue, but I've tried running power directly to the pump (which is now working) but still no fire.
    Any ideas?
    Perth, WA
    Default Re: The Beams is in my Celica, but I can't get it to start
    got sparks?
    Twisted ****** Backyard Mechanic .T.'s Avatar
    hardly played with this model of 3sge, but things to check:
    as chb said - spark
    stupid clutch pedal isolator starter thingy (easily bypassed)
    check all your connectors - esp ecu
    earthing points!!!
    fuses - easy to blow fuses when doing this sort of conversion.
    if it turns over, & you have fuel & spark, it will start
    T
    Dont these have a fuel pump ecu?
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Melbourne Victoria
    make sure all of the earth wires are bolted down and are making good contact especially the coils and injectors
    Mar 2010
    Thanks guys, I'll give these things a go later today.
    Mar 2010
    Quote Originally Posted by CHB View Post
    got sparks?
    No spark. I think I'm doing it properly, but I've never tried on an engine with no distributor or normal leads. I've pulled the spark plug out and run an earth wire from the body to the plug, with the plug still plugged into the lead. When I turn the engine over, there is no spark. This is the right way to do it, right?
    Quote Originally Posted by .T. View Post
    as chb said - spark
    earthing points!!!
    T
    All plugs seem fine as well as the earthing points. I'm going through all of the fuses but haven't found any issues yet.
    What is this clutch pedal isolator? I've checked the pedal on the donor car and can't find any switches or similar. Would this stop the engine from cranking at all, or just stop the spark?
    Quote Originally Posted by StuC View Post
    No idea, but the engine started fine when it was still in the half cut.
    Quote Originally Posted by Celica RA45 View Post
    I've checked these and everything seems to be fine.
    Any other ideas? This is driving me crazy!
    how did you wire up the ecu? When i wired up my car I had the same issue as you which all came back to a single black 12v wire which provided power to the coilpacks.
    get a 12v test probe and start testing your modules. you will notice that you're not getting 12v to them. trace this back and there is a 12v wire which goes straight from your IGN relay. I'll double check this all for you tonight as I wired this thing up 3 years ago.
    so you swapped ALL the looms from the cut? I'd be checking that the EFI main relay is being triggered by the ECU, if not, trace back looking for blown fuses etc.
    Did you repin any of the looms that run to the rear of the car?
    do you have the check engine light and also the diagnostic port (in engine bay or cabin)? If so, is it displaying any error codes when you connect Tc to E1 in the diag port?
    (someone may want to chime in here if the diag port names are wrong)
    edit: thanks wilbo!
    Last edited by thechuckster; 27-04-2011 at 02:56 PM. Reason: corrected Test port name
    do you have the check engine light and also the diagnostic port (in engine bay or cabin)? If so, is it displaying any error codes when you connect TE1 to E1 in the diag port?
    Pretty sure it's Tc to E1
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2006
    tas
    Quote Originally Posted by one View Post
    The coils should have constant power while the ignition is at the 'on/run' position, they are then triggered by the earth wire by the ecu for them to spark. Im finding it a learning curve with my first modern engine conversion.
    So to test it you would need to remove a coil, fit a spark plug then crank it.
    But as mentioned before if it has fuel, spark and cranking it will fire (assuming cam/ignition timing is correct or close).
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Mar 2010
    Things are going backwards now... the engine won't even turnover. The relay on the ECU is not being triggered (it was previously) so I can only imagine I've bumped something, but I've checked every connection and fuse and I can't find any issues. I don't know if this is related, but also my headlights are no longer working (they were previously).
    If it helps at all, here's a run down of what is working and what's not working:
    Working
    Dash lights
    Tail lights
    Brake lights
    Indicators
    Climate control (installed from the half cut)
    Central locking
    Power windows
    Power mirrors
    Not Working
    No spark
    Engine won't turnover (was fine yesterday)
    ECU relay (was fine yesterday)
    Headlights (was fine yesterday)
    When I turn on the ignition I get the oil light and the ABS light (which turns off after a few seconds) but I am not getting the check engine light or the battery/charge light.
    I even tried plugging the factory stereo back in (from the front cut) in case there was some sort of factory immobilisor, but that didn't help. The stereo wouldn't turn on either, although I'm not sure if it worked originally.
    Quote Originally Posted by horse View Post
    The ECU was plugged in using the loom from the front cut, I haven't changed any of the wires or plugs. I don't have a test probe, but I think I'll be investing in one shortly!
    Quote Originally Posted by JP View Post
    I swapped the engine loom and both interior (front only) looms. I haven't changed the looms that run through the front guards, and I haven't repinned any of the looms which run to the rear of the car.
    Maybe changing the loom/s that run through the front guards would be worth a shot, as it does attach to the fuse box on the passenger side.
    No check engine light. There is a diagnostic port in the engine bay, but I've never played around with it before. Might be time to start?
    Mar 2010
    Okay thanks, well sounds like I was doing it right then. I need to get a test light so I can check whether or not power is getting to the coils.
    just find a small 12V lamp (e.g. one of the backlights for a dash) and connect it across Tc and E1 - it should flash codes (or if flashing steady, is saying no errors).
    Later on, you should work out why the check engine light in the dash is not coming on (with IGN on and engine not running).
  1. 3SGE BEAMS into RA65 celica.
    By sumfancyname in forum Tech and Conversions
    Last Post: 05-06-2021, 08:17 AM
  2. 22RE - common problem ? Hard start? Cold start injector?
    By Toyocorona in forum Tech and Conversions
    Last Post: 20-01-2010, 08:41 PM
  3. Replies: 12
    Last Post: 10-02-2009, 07:33 PM
  4. ST202 Beams celica - LSD box? S or E series?
    By Mooro in forum Tech and Conversions
    Last Post: 25-02-2007, 12:11 AM
