Results 16 to 23 of 23
Thread: The Beams is in my Celica, but I can't get it to start
    Default Re: The Beams is in my Celica, but I can't get it to start
    Chuckster, I think you mean put the bulb across 12V and the W terminal. Tc and E1 get shorted together to put computer into diagnostics.
    May 2006
    tas
    a lot of that on the 'not working list' are different circuits outside of the engine wiring loom.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    which fuse box are you using then? the st204 or st202? From memory there are certain differences so you're best to start checking that all connections are correct. I'm hoping you have grabbed the fusebox and looms (including all junction boxes and relays) out of the cut and placed it into your car.
    Secondly when cranking are you getting fuel through the rail?
    Oh and is the battery fully charged?
    Edit: Manual to manual conversion? or manual to auto ? or auto to manual?
    If auto to manual you will need to bypass the Neutral Start Switch.
    Mar 2010
    Quote Originally Posted by horse View Post
    how did you wire up the ecu? When i wired up my car I had the same issue as you which all came back to a single black 12v wire which provided power to the coilpacks.
    get a 12v test probe and start testing your modules. you will notice that you're not getting 12v to them. trace this back and there is a 12v wire which goes straight from your IGN relay. I'll double check this all for you tonight as I wired this thing up 3 years ago.
    So I bought a multimeter today and checked the ignition modules. With the ignition on (or off for that matter) I'm getting 5v to the red with black stripe wire, and nothing to the other wires. I recall reading something on the MR2 forum about a guy also getting only 5v, but now I can't find the thread.
    Yes, manual to manual. No fuel presure unless I run power directly to the pump.
    Quote Originally Posted by RA35GT View Post
    My diagnostic box doesn't have anything in the W terminal.
    Anyway, I'm going to swap over the front chassis loom today and see if that helps.
    Shane.
    Mar 2010
    Swapped over the front chassis loom, still no start! The ECU relay is opening when I try to start, but the engine is not even turning over.
    Anyway, I have accepted defeat and have booked in an auto electrician to come and take a look next week. I just can't work it out, I swapped everything now besides the metal bodywork and it just won't work! Oh well...
    I'll update this thread with whatever the auto electrician comes up with, hopefully it will be of help to someone down the track.
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    Punch it, it will come good.
    Mar 2010
    You wouldn't believe it - it was just a loose plug and a missing fuse! I'd checked everything a million times, but I guess it takes a fresh pair of eyes to pick these things up sometimes.
    Felt a bit stupid to get an auto electrician out just for that, but at least it wasn't anything major. $80 well spent I say!
    The Beams sounds so good without an exhaust.
    haha congrats mate! now enjoy it
  1. 3SGE BEAMS into RA65 celica.
    By sumfancyname in forum Tech and Conversions
    Last Post: 05-06-2021, 07:17 AM
  2. 22RE - common problem ? Hard start? Cold start injector?
    By Toyocorona in forum Tech and Conversions
    Last Post: 20-01-2010, 07:41 PM
  3. Replies: 12
    Last Post: 10-02-2009, 06:33 PM
  4. ST202 Beams celica - LSD box? S or E series?
    By Mooro in forum Tech and Conversions
    Last Post: 24-02-2007, 11:11 PM
