Those plugs you have pictured are they on the inside side of the engine wiring harness (opposite side of the main grommet to all the other wiring plugs) If so they are the power supplys, earths and instrument wires.
The white one you have circled up in the first picture should have colours brown and brown/black - these are earth wires and are the only ones needed in that harness, the others are for ABS diagnostics and instruments displays that you don't need.
The plug in the second picture top right
Green - fuel pump control relay
black/white - neutral start switch
red/green - fuel pump control relay from ecu
black/orange (2 wires) - fuel pump control relay
black/red - fuel pump control relay
Pink - fuel pump control relay
all the fuel pump control wires, the only one you require is the one from the ecu to switch your power on/off, just wire the rest as a normal relay and the computer will turn the relay on/off for you. From memory the Pink one is the signal wire.
And then there should be another plug there - possibly the second picture lhs that has these colours.
Black/yellow - alt supply - requires a 7.5a ignition source
black/orange - Ignition switch - requires 7.5a fuse in on position of switch
And one more connector or maybe one of the ones I mentioned already has these colours
yellow/black - oil pressure gauge
blue/yellow - check engine light
yellow/green - water temp gauge
black - tacho
purple/red - oil level light
These ones are usually all in the one connector so you should be able to nut that one out. There is a few more power wires required but they are in the fuse box assembly so depending on how your wiring it all up you may have that connected somewhere else in the harness.
I hope that helps a bit
Aaron
