Yeah that's the going rate for billets, not many budget ways to get around if you want really big cams.
One trick many forget with bucket cams is if they are quite meaty in the base circle and you can put custom thickness shims under the bucket (will dig up the mob in melbourne if anyone wants some - $8 each) and gain a bit over a mm of lift and 10-20 deg of duration on cam with 1mm of base circle to play with. I had a look at 20V cams a while back and believe you could get a bit out of them with a grind. $120 each for a regrind and $160 in shims and you could be in the 270 duration mark with over 10mm lift. By shrinking the diam of the base circle you get a more aggressive ramp rate too, which will aid spool time.
