Results 1 to 2 of 2
Thread: 1UZ cam tensioner
    Feb 2011
    sa
    Default 1UZ cam tensioner
    Before I undo the wrong bit and spidiong !!Can someone confirm how the cam tensioner is safely removed - is it by rotating the allen bolt to lock or unlock
    Rob
    Aug 2009
    Default Re: 1UZ cam tensioner
    are you talking about the timing belt tensioner?.. if so firstly obviously time the motor up, remove the hydraulic tensioner and thats it youll be able to remove the belt..
    then you have to reset the hydraulic tensioner by compressing it slowly in a vice and locking it with a pin or tiny allen key.. and reinstall, also its a good idea to remove that allen key bolt and clean it, i put antiseize on it and behind it to make sure it doesnt sieze up..
  1. 1jz tensioner pulley
    By Hydra in forum Tech and Conversions
    Last Post: 29-08-2008, 10:55 PM
