Results 1 to 5 of 5
Thread: R154 jumping out of gear
    Team Thrash Garage's Grease Monkey VikingDrift's Avatar
    victoria
    Default R154 jumping out of gear
    Hey guys, my box won't stay in first, jumps out of third and is noisy in second (selector hitting second gear). I pulled it down, couldn't see anything wrong, except it didn't look like it was engaging into first the whole way. I noticed that the bolt on the first/second selector was loose as so I tightened that but that didn't fix it
    Is it possible that the selector is bent? Any other possible issues?
    Wes
    RT-142 daily drifter, now JZT-142 , projects: hk prem, 40series cruiser, MX-22
    corollamanic Backyard Mechanic
    May 2006
    Default Re: R154 jumping out of gear
    Spoke to a dude yesterday (PRIMRK on 86dc) that mentioned a critical spacer that if broken can cause your gearset to move and mesh gears that aren't meant to causing death to gearbox. even though this ain't your problem here, would be worth looking into to prevent this happening.
    Oct 2007
    isnt this a thrust washer? or is that only for first....
    Apr 2010
    queensland
    mine did the same and it was the thrust washer mate. replaced it and all was good. but if you keep driving it as it is (if possiable) it could do more damage. driftmotion.com do a upgrade for them thats stronger then the factory thrust washers.
    victoria
    Nice i'll check it out cheers! I haven't been driving it so hopefully it'll be all good.
  1. Speedo gear for R154 gearbox
    By rogue-vl in forum Tech and Conversions
    Last Post: 18-09-2010, 10:54 PM
