Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: 4age Very Low comp on cyl 3 and 4
    Default Re: 4age Very Low comp on cyl 3 and 4
    yeah but no mention there about removing cams.... you can leave them in on a 7m if you have a long head bolt tool. short tool requires removal of cams.
    sounds like the 4ag needs cams out to get to head bolts.
    Never late in an x8
    Junior Member Grease Monkey toyoda's Avatar
    Yo,
    Definately need to take out the Cams.
    As said above, loosen all the bolts at the same time a bit at a time so you don't snap the cam.
    Worth setting it on top Dead Centre (TDC) and checking all the marks on Front Pulley and Cams line up before you pull it apart, just so you know what you are looking for when
    setting it back up again.
    You will probably have to pull the Distributor out to gain access to one of the Head Bolts - again look at the marks before you pull it out.
    Good luck
    Toyoda
    Hachi Rusto Backyard Mechanic Julz01's Avatar
    well 7 months later and we are no better off then I started, head still isnt off but getting it taken off next week and checked out, just wondering do you need to change the head bolts when changing the head gasket or can they be reused.
    thanks
    Chiba
    Grab a Toyota manual and a set of vernier calipers. If they measure within spec, then you can reuse them.
  1. High Comp 4AGE Forged Piston Question
    By RT40Corona4AGTE in forum Tech and Conversions
    Last Post: 14-10-2010, 01:31 AM
  2. hi comp 4age with 4agze pistons
    By legend in forum Tech and Conversions
    Last Post: 30-07-2008, 09:26 PM
