Results 1 to 11 of 11
Thread: Boost - 1ggte
    Feb 2011
    Default Boost - 1ggte
    What rpm would you expect to have full boost by in a 1ggte??? (Standard)
    I have just bought an RA65 with a 1ggte in it, & it seems reallly laggy for such small turbos.....the boost isn't coming on until between 3500rpm & 4000rpm !!!
    I was told by a local tuner that it doesn't come on until this rpm, and that there wasn't any real way to remedy this...
    Could someone clarify whether this is correct, and if it isn't, how to overcome it??
    thanks
    Default Re: Boost - 1ggte
    3500 sounds about right when mine was stock, better cooler and exhaust would help abit, best solution is to get rid of them and go single.
    88 gz20 soarer built 1ggte gt30/40 osgiken twin plate j160 gearbox.
    Jan 2007
    I have owned a stock car (ga70) with nothing more than a cat back exhaust for a few years now, and I am sure that it starts to come on boost by 2000rpm, and is on full boost at 3000-3500rpm. Although I have to admit that it has been along time since I have driven the car so I could be mistaken.
    Positive pressure by early 3's then full boost by late 3's is standard for a 1ggte. They really benefit from newer turbo tech turbos.
    RA23 - Twincharged
    JZZ20 - Daily
    West Australia
    depends what gear your in..
    2nd at ~3000 rpm
    3rd at ~2500 rpm
    for my stock 1ggte back in the day.
    what the admiral said is my general belief from the time i spent with a stock turbo 1g in my ke70, the more load it had the earlier it will spool obviously
    Aug 2010
    i hear the 1g runs 6psi boost stock, im keen to up the boost but how much is safe???
    thanks =]
    1 bar is fine, they run crazy rich anyway. Full boost by 3300 on stockos, my experience.
    Aug 2010
    whats that in psi??? soz a bit new to all this stuff
    14 psi ~= 1 bar
    RA23 - Twincharged
    JZZ20 - Daily
    Google?
    Google
    Wilbo's JZA80
    Wilbo's JZZ12
  1. 1GGTE running like a pig on boost - help
    By Stomp86 in forum Tech and Conversions
    Last Post: 16-09-2010, 12:52 PM
  2. 1ggte boost issue
    Last Post: 18-02-2010, 08:33 PM
  3. boost 1GGTE
    By cagiva97 in forum Tech and Conversions
    Last Post: 08-04-2008, 01:57 PM
  4. more boost on 1ggte!
    By rollsy in forum Tech and Conversions
    Last Post: 27-03-2008, 01:46 PM
  5. 1ggte cutting out under boost
    By VasH in forum Tech and Conversions
    Last Post: 27-02-2008, 04:22 PM
