Results 1 to 6 of 6
Thread: Toyota Crown 4M Sump hump relocation
    Jan 2008
    Default Toyota Crown 4M Sump hump relocation
    Has anyone ever had a go at swapping the location of the oil pickup hump on the 4M Toyota Crown sump and by using an extended oil pickup tube. We'd love to use a 4M engine in a rod were building and we don't want to modify the subframe so by having the hump moved from the centre to at the rear this would correct the problem.We have a Tig so using a spare sump for the modifications won't be a problem but would the oil pump handle the extra tubing distance.
    Default Re: Toyota Crown 4M Sump hump relocation
    M series sumps come in 3 arrangements.
    -Front
    -Mid (what you currently have)
    -Mid-Rear
    Have you looked at using a Mid-Rear sump as found on 7MGE in MA70? This might work out of the box, or at least be a better starting point for mods if required
    Sumps across all M series are interchangeable, however you also need to swap oil pumps and may need to drill the engine block to relocate the dipstick etc.
    Wilbo's JZA80
    Wilbo's JZZ12
    Jan 2008
    No never knew of the different locations of the hump and does the 7MGE in MA70? have the same mounting hole, I'll see whats on google images.
    Quote Originally Posted by 1975ToyotaCrown View Post
    Sorry, I'm not sure what you mean by 'mounting hole'
    What do you mean?
    Wilbo's JZA80
    Wilbo's JZZ12
    Jan 2008
    Where the sump mounts to the block, I've now looked up 7MGE and there is some difference. We started doing the mods to the 4M sump last night using 2 sumps.
    Last edited by 1975ToyotaCrown; 09-03-2011 at 08:28 PM. Reason: Learning to type in the dark.
    Act
    I'm running a 4M sump/pick up on my 7M to get it to fit into the crown. so it would work the other way. I'm sure I have a MA70 sump I could take some pics of the and its yours for postage.
  1. Toyota Crown MS53 Crown Custom Wagon
    Last Post: 23-06-2011, 11:44 AM
  2. Hump Bonnet For Ta22
    By andrewta22celica in forum Tech and Conversions
    Last Post: 17-04-2009, 09:18 PM
