Page 33 of 43 FirstFirst ... 233132333435 ... LastLast
Results 481 to 495 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #481
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Default Re: Megasquirt users thread to discuss all things Squirty
    Possibly, I'm now having problems with the DB-9 to USB connection so will replace that with a different one and re-check everything.
    Yes it was blinking continuously with the other two
    SR20DET TA23
  2. #482
    flashing fuel pump says error but at least it also means the ECU is alive.
  3. #483
    Aug 2008
  4. #484
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Neat, I didn't realise we had a Megasquirt thread. Subscribed for later.
    Not a Toyota, but my daily Handi is running a Megasquirt.
  5. #485
    Feb 2010
    ^that is so cool! anymore info on it?
  6. #486
    May 2006
    In a nutshell, it's a '98 Sirion motor in an '86 Handi, upgraded to EFI (tank, lines, wiring, etc.) running a MSII v3.0, MSExtra firmware and modified throttles from a GSX-R 600. Nothing too extravagant, but sounds awesome and the throttle response is nice and crisp.
  7. #487
    Apr 2010
    Okay turns out the route to my problems was a crappy Belkin USB-DB-9 connector, Have since gone DB9 straight through and the car the 2TG is up and running!
    Now up to the tuning stage and setting my VE map, the table generator looks as though it's going to work well but i'm unsure as to what MAP to put in the peak HP and peak torque settings at?
    I have 53map/KP set as my idle as that's where it was idling around.
    I also don't get an RPM reading whilst cranking, although motor fires and runs after a few cranks.
    Possibly VR wired backwards?
    SR20DET TA23
  8. #488
    is power to MS maintained during cranking?
  9. #489
    Apr 2010
    Yes and remains on the laptop screen with everything working other then the RPM signal but then fires into life and shows RPM above 400
    SR20DET TA23
  10. #490
    how about power to coil? power to injectors?
    could be VR, easy to test
  11. #491
    Oct 2009
    MS2 PNP 4AGE
    Wideband
    Coming my way, as it stands engine has a set of poncams. It runs well enough but likes to stall and the idle has to be all the way up
    Never really tinkered with this kinda stuff before but surely it cant be that hard to improve it and have it idle. Wonder if it will really just plug in and start lol
  12. #492
    Jul 2009
    You picked up one of these? http://www.diyautotune.com/catalog/m...2re-p-503.html
    Interested to see what the MS-PNP is like compared to the DIYPNP and if it's really worth the extras $$
    Remember, download Tuner Studio (or buy the full version for auto tuning) and don't use MegaTune/Megatunix
  13. #493
    Oct 2009
    I'm happy to pay a bit more to keep the loom, few disadvantages but I accept that
    I couldn't justify the cost of a adaptronic or whatever, if a little box of electronics from 1986 can run an engine well enough then I'm sure this will be fine.
    Plan is to get it running, do some basic self tuning and depending on how that goes, pay for a few hours on a dyno.
  14. #494
    looks like fun
  15. #495
    Oct 2009
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 04:39 PM
