Page 32 of 43 FirstFirst ... 22303132333442 ... LastLast
Results 466 to 480 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #466
    New Zealand
    Default Re: Megasquirt users thread to discuss all things Squirty
    This was the pinning I put together for my V2 V3.57 with the DIY Autotune loom -
    DB37 Plug
    1 Earth - Air Temp
    2 Earth - Coolant Temp
    3 SPR1/CANH
    4 SPR2/CANL
    5 SPR3
    6 SPR4
    7 Wideband Signal Ground
    8 Hall Sensor Braid
    9 TPS Earth
    10 blank
    11 blank
    12 blank
    13 blank
    14 Good Engine Earth
    15 Good Engine Earth
    16 Good Engine Earth
    17 Good Engine Earth
    18 Good Engine Earth
    19 Good Engine Earth
    20 Positive - Air Temp
    21 Positive - Coolant Temp
    22 TPS - Signal?
    23 Wideband Sensor
    24 PIP - Pin 1 EDIS
    25 IAC 1A
    26 TPS Sensor - 5V feed
    27 IAC 1B
    28 12V Feed - through 3W fuse
    29 IAC 2A
    30 PWM Idle Valve
    31 IAC 2B
    32 Injector Earth - Bank 1
    33 Injector Earth - Bank 1
    34 Injector Earth - Bank 2
    35 Injector Earth - Bank 2
    36 SAW - Pin 3 EDIS
    37 Fuel Pump Relay - Pin 85 or 86??
    Modded a bit to show my EDIS connections but may be of some help.
    Callum
  2. #467
    Oct 2009
    shrike: are you sure the ECU is feeding dash info other than a tacho output? From that era of engine, there should be a separate temp sensor for the dash, the alt light & other wiring simply passes thru and some of the interconnect goes the other direction (e.g. circuit opening relay, EFI #1 & #2 relays, etc.).
    Anyway sharing sensors that are resistive (TPS, CLT, AIT) isn't advised and I'm pretty sure that a VR sensor (e.g. CAS/dizzi) would also be an epic failed if shared.
    fwiw, I approached the problem in my RA65 from the other direction, I worked out which signals the chassis loom needed, then either passed the wiring thru from the engine bay fuse/relay box or got the ECU to generate it.
    Factory ecu controls dash abs and a few otherthings im splicing into the power and ground to the factory ecu and disconnecting all the engine controls/sensors the water temp sensor for the dash is seperate to the ecu temp sensor so ill leave that one alone
    So pretty much the ms3x will control the engine
    also the dash tacho input I dont need to wire into with the ms3 i will do a write up when I do it just waiting on the car to be ready and the ms3 to arrive from the states
    I have all the factory wiring exposed in my project car and its a c**t to seperate it
  3. #468
    shrike: that sounds like a PITA. You'll have to get a tacho signal from the MS3 to the dash somehow - the factory ECU will be generating it from it's own internal control or is it coming from the ignitor?
  4. #469
    Oct 2009
    Its coming from the igniter so I can leave it alone thankfully and yes it is a pita but oh well I spent the last week working out all the wiring and I should be able to run the 5v signal to the ignitor from the spark a ref on the ms3x or the other option is to use the tacho out but Ill see what works best in car
  5. #470
    I thought the 3-wire O2 sensors had a wire for pos and neg of the heater, and the sensor ground was on the body.
    putting the neg of the 3wire into the shared ground for the sensors would contribute a couple of amps and possible cause issues?
    I like putting high current grounds direct to a battery connection, just in case...
  6. #471
    Jul 2009
    Finally got around to making up a tacho booster circuit so the DIYPNP tach out feature could drive the AW11's stock tacho.
    Reads a fraction high on the tacho. Limiter is 8500 and it holds it under 8600 when bouncing off the limiter, but the tacho shows near 9000rpm.
  7. #472
    Feb 2010
    Quote Originally Posted by knightrous View Post
    Do you know if this is similar to what the SW20 clusters require? People on MR20C said replace one of the resistors on the PCB for the tacho with a different value (cant remember). So i did it, and my tacho reads about 200rpm above my actual idle speed (reads 1100rpm when im at 900rpm). when revving you cant really tell tho so its fine there, but it makes my car look like its running a high idle. Was thinking of just making it back to stock and making the tacho booster. MS3/MSx tacho output is the same sigal as MSPNP right? and i think the AW11 and SW20 have the same tacho input signal?
  8. #473
    Jul 2009
    If your just running the standard ignition setup, you shouldn't need to do this as your dash tacho will be driven by the stock coil.
    You only need to use the tacho booster if you switch to COP or Wasted Spark setups. The guys on MR2OC might be right with changing/adding a resistor to the tacho feed as to adjust it, but I've no experience with this. Stock tacho's are generally out by some extent, so I trust the MS over the stock tacho
  9. #474
    Feb 2010
    haha yeh i trust the MS too. I changed to COP, running great. But yeh, using the MS tacho output to the tacho i changed the resistor to another one (stock 48k to 15k i think i used or 12k), people using hydra nemisis and stuff like that have no issues, and they produce the same output signal as the MS so should be fine i think, i expect the tacho to be off, but not that much at idle, its silly haha.
  10. #475
    Jul 2009
    Try putting a potentiometer in there and adjust it till it's perfect, then put a dab of hot glue to hold it into position.
  11. #476
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    WDE BDY and chuck thanks for the wiring help, all seems to check out thanks +rep to you two
    Latest problem is
    Went to check oporation of everything again and configure my TPS, plugged everything in and powered it up,
    All the LEDS on the megasquirt blinked then went out, then nothing - I can't get a singnal through the computer either
    Through tunerstudio I went to the COMM settings and went detect and it found the megasquirt but says that no firmware is installed therefore can't do anything?
    Re-did the download/installer of the computer and this took around 15 minutes through their downloader program (which I re-downloaded to make sure I got the latest version)
    Yet the computer still reads no firmware!
    Any body got an idea?
    SR20DET TA23
  12. #477
    Feb 2010
    using windows right? Have you made sure you have the latest version of the USB com drivers for the MS unit? its in the manual (this is if you're using USB)
  13. #478
    Caam: pull the ECU out of the car and attach to a sim - then try to connect with the laptop.
    Also, check all the fuses feeding it. Plus, open the lid and make a visual inspection (torched bits or the daughter board come loose or insulated jumper wires rubbing or caught.
    does the V3 board have bootloader jumper pins like the older boards? (will go to the msextra site and confirm)
  14. #479
    Apr 2010
    Yep windows XP and have the latest drivers and it was working fine sunday night when I checked CLT/IAT sensors and everything repsonded fine through the car.
    Wiped the current firmware again and re-installed it, this time it worked through the stim however no RPM signal which obviously means no o2 signal aswell - i'm running VR and I know this can be hard to test through the stim.
    Plugged it into the car and laptop, powered it up and once again wouldn't connect with the laptop, but this time all the LED's on the megasquirt blink continuously while it has power.
    Pulled it out and check stim, same thing. No signal on the computer and LEDs blink continuously
    Visial check shows nothing out of the ordinary
    Yes the v3 board has bootloader jumpers on the daughtercard and they were connected while installing the fireware and removed afterwards
    SR20DET TA23
  15. #480
    it does sound like something in the car wiring has borked it.
    Is the fuel pump LED flashing along with the others or just staying on?
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 04:39 PM
