Results 1 to 11 of 11
Thread: MX83 Aircon clutch relay - where is it?
    Default MX83 Aircon clutch relay - where is it?
    Afternoon all,
    Been trying to get the aircon working in my mx83. Close to nutting it all out (I hope) - just need to confirm where exactly the relay for the a/c clutch is (magnet relay?). I have many wiring diagrams, we just can't find where it is physically located.
    Maybe related, maybe not - if anyone knows what the relay on the bottom right of the blower setup behind the glovebox is, pins facing toward back of the car - that'd be great. And the large blue plug that lives near it..
    Will be going to pick n pay for a look today, but more info the merrier...
    Engine is (i think) JZX90 1JZ.
    Thanks
    Bardin
    Default Re: MX83 Aircon clutch relay - where is it?
    Right, so i looked at 2 untouched grandes at pick n pay, and neither of them had said relay on the heater box or the blue plug. Rigggggggggggggggggggggggght.
    Sounds like fun...Still driving around with no dash?
    Sep 2010
    The relay is located next to the battery in the black cover where the other relay and fuses are. It is marked MG CLT and is the round Toyota relay. Hope that helps you cheers Tom.
    Confirmed. Worse now because the kick panel wiring is all hanging out too. The bit with the hazard light switch etc is just hanging on by its wiring, etc. Fun times
    It would seem i may have a jzx81 loom (??) because a fair few things are noticably different to the mx83's at the wreckers.. but still very stock looking. The only saving grace is that the a/c trigger wire seems to be colour coded the same
    Quote Originally Posted by Toms JZX83 View Post
    Ahhhh looked there but was looking for something like a/c.... knew it had to be staring me in teh face the whole time
    Has the aircon got gas in it. They wont run without. It has a min and max pressure switch. Wont run without gas or with too much pressure.
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    as amichie said there is a low pressure switch, also there is a 10A fuse behind the passenger side kick panel. The regulator on mine was leaking so i couldn't get mine to work things are practically impossible to get or fix easily.
    Quote Originally Posted by amichie View Post
    No it doesn't - but you also can't gas it unless it will turn on... so here we have the dilemma - I tried to have it gassed previously, but because it wouldn't turn on, it couldn't be gassed fully.. But then like you say, it won't turn on without gas in it.. dilemma
    Reeeeeeeasonably confident the issue is fixed now, bar the fact that my compressor leaked the small amount of gas that was in it. Changing compressor and o-rings this afternoon, and then will have another crack at getting it gassed on the weekend hopefully. As for whether or not it will idle up i have no idea... but thats a problem for later
    Feb 2008
    Quote Originally Posted by Bananaman View Post
    make sure you get it pressure tested first and checked for leaks. Otherwise you'll be back there in a week or so with no gas.
    You can bridge the pressure switches with the ignition on(engine off) and check to see if the magnetic clutch engages when you turn the a/c on/off.
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    Quote Originally Posted by chaserbuddy View Post
    Yeah will do. I'm planning on driving interstate with the car in a week,. so i'd prefer this doesn't happen
    Quote Originally Posted by mr1jz View Post
    Yeah was planning on doing this if i've got time tomorrow.. we'll see.
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Replies: 6
    Last Post: 08-01-2009, 11:57 AM
  3. All About Relays: Identification, Uses & Prices
    By infotechplus in forum Tech and Conversions
    Last Post: 17-02-2007, 10:52 AM
