Results 16 to 30 of 33
Thread: 7mgte in a hilux
    Feb 2011
    wa
    Default Re: 7mgte in a hilux
    does anyone know wat wires i need to hook up to power up the ecu
    Junior Member Grease Monkey 81hilux09's Avatar
    Apr 2009
    if its anything like the 1G, you need ign, cons, ground direct to the ecu than there are 1or2 other wires in the engine bay to power the injectors and something else (its been 12months since i did mine). get a wiring diagram and try to trace your main power wires from + to the ecu.
    Mine had a M-rel too that needed ign power aswell.
    The W58 will be fine as long as you are gentle (no flat shifting). I'm pushing 487rwhp through mine and its still going strong.
    That said I'm sure its my complete lack of traction that is stopping the W58 from turning into metallic confetti. But then again, if you've somehow got it mated to the transfer case, then traction is going to be the least of your worries.
    Feb 2011
    wa
    its still not constant 4x4 tho and cos its my fourby it wont get thrashed too much and i got a few spare gearbox just in case but yeh hopefully it lasts a little while
    Apr 2008
    how r u coming along man?
    Feb 2011
    wa
    got the bellhousing yesterday so just waiting for the flywheel and clutch and ill have it going
    Feb 2011
    wa
    Feb 2011
    wa
    ok so ive hit another wall now, i used a 7mgte flywheel and just redrilled the holes for the non turbo clutch but now the pressure plate just touchs the side of the bellhousing where it curves toward the gearbox anyone got any ideas at all?
    Act
    how much buy?? will some love to the bell housing fix the problem??
    Feb 2011
    wa
    yeh i fixed it with a 6mm spacer plate in between the engine and box. this swap is taking a lot more than i expected so hopefully will be worth it once its done
    Act
    is the gearbox still going to engage the clutch with the spacing??
    Feb 2011
    wa
    yeh it still engages fine just needed to put a slightly longer slave rod on it im in the middle of wiring it all up at the moment hopefully will have it driveable this weekend
    Feb 2011
    wa
    hey can anyone tell me how to wire up my alternater for the hilux the 18r one only had 2 wires and the 7mgte one has 3 im stumped on it can anyone help
    I would have thought the 18R one would have an external regulator
    On the alternator 1 wire goes to ignition 1 goes to 12v and one goes to the warning lamp
    Jealousy is a curse
    Apr 2011
    From memory on mine, the thick black wire goes to the post, the white wire goes to the post aswell which goes to your battery, I think the thin black is ignition and can't remember the yellow, I did the same conversion. I deleted the external regulator because couldn't be used with the loom
    I used a r154 bellhousing and a early lux bellhousing and got it cut and shut shortened 30mm, used the 7mgte flywheel redrilled it and got a 7mge exedy heavy duty full face clutch, used the clutch fork and holes and shit off of the lux setup. But I used a r150f box which is the same setup as a r154 with the pattern, alot bigger/stronger than a g52
    Here are a few pics of the bellhousing etc
    It was a tight fit aswell
    And this is what it's all in
    Alot of fucking around but was worth it, have had it on the road for abotu a week, so if you wanna wanna ask or know anything throw me a pm, I'll see if I can help
  1. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 08:27 PM
  2. 7mgte power results (6 / 5mgte's welcome)
    By mux in forum Tech and Conversions
    Last Post: 16-08-2007, 06:41 PM
  3. Hilux Tow Bars and Wheels
    By Son of Toyoda in forum Tech and Conversions
    Last Post: 26-06-2007, 07:09 AM
