Use the original AE92 pressure switch. The AE111 switch is a dual-pressure switch so you could just use the low side if you dont have the AE92 unit.
For the compressor you only need to connect the clutch trigger, the AE92 AC ECU doesn't have a speed sensor input so you can ignore those compressor wires.
Pull the lid off the original AE92 SX ECU and the pinouts are printed on the PCB.
