will 4AGE Blacktop throttle bodies be big enough?
seeing as a smooth idle isn't manditory, mount the injectors up the runner away from the head (RX7 style) to improve torque? you're making a custom induction system so injector placing is up to you.
edit: nearly forgot - crazy conversion!! would be great if Australian rallying let you modify cars like you folk in NZ can. Is a shame you can't convert the rover to 4wd and use ST185 or 205 suspension/transmission? ... priced a SADEV box as per the super2000 class?
Not mentioned in my list, but a Davies Craig EWP with a controller is going to be used. Will gut the stock water pump and ditch the thermostat. Water pipes/hoses will be at an absolute minimum. One to the rad and one back from the rad. Simple as
