Bit of background behind my issue:
The dynamic balancer only spun upto ~3000rpm, and was perfectly balanced.
However, when in the car, top or 4th (being 1:1) had the shaft spinning at ~6500rpm on the track.
Also run up on axle stands (safely of course) you could see the shaft go into 'skipping rope' mode.
Back at the balancers, even with weights (considerable) added to the middle of the shaft it could not replicate the issue.
The tube diameter, wall thickness & length all 'seemed' to be within the acceptable range to not have the issue, but was clearly not the case on 3 different shafts.
2.5" thick wall, 3.0" thin & thick wall tubes, the last being the best (or the least worse, good england there). Thus, back to a 2pc shaft.
