Results 1 to 7 of 7
Thread: 15" Wheels on AE92
    May 2006
    Default 15" Wheels on AE92
    I am after some information on fitting 15" wheels with 45mm offset on a AE92 Corolla SX with Standard 39mm offset.
    Has anyone done this fitment?
    Does it require a spacer to move the rim & tire away from the Shock Absorber?
    Thanks,
    James
    Roadcar - 2006 Ford Territory TS (Got to love company (tow) cars)
    Racecar - 1990 Toyota Corolla SX
    Racecar - F304 Dallara Renault (ok, not mine but spend enough time engineering it! )
    Default Re: 15" Wheels on AE92
    what width?
    May 2006
    I knew I shouldnt rush to post the message before lunch.....
    Anyway, I am looking at current Toyota Corolla 15" x 6" rims with a 45mm offset.
    Car is only used on the track so modifications can be done if required.
    Regards,
    James
    hm... if it doesn't scrape when u use it, then dun worry about a spacer.. the rolla can take a fair bit more than that i reckon..
    be fine but you might want to go a bit wider for the track!
    May 2006
    Thanks guys,
    Will give these a try to start with, as the rims are cheap and then if I feel i need to go wider will look at what is out there.
    Regards,
    James
    cheap as in $300 or free
    By The Witzl in forum FAQ
