Results 1 to 9 of 9
Thread: 89 cressida cut rear springs
    Jan 2011
    Default 89 cressida cut rear springs
    heya all
    im new to the toyota scene
    i scored an immaculate 89 cressi for $300, we cut 2 coils off the rear springs the springs unseat themselves and now i have scraping and rubbing in the rear end, whats the best method to keep them in until i can get k-macs?
    also the sunroof doesnt work
    any help would be most excellent
    Default Re: 89 cressida cut rear springs
    uncut springs would help.
    Jan 2011
    i know this
    that dont really help the question at hand lol
    Melbourne, Victoria
    ....the best method is to go to the wreckers and get some uncut rear springs and put them in.
    There isn't a thread on here or any sound reason that suggests cut springs are the way to go so just don't do it. Do it properly or not at all.
    As for the sunroof not working it could be just the switch or the motor. An auto elec would be able to tell you without too much messing around.
    Being new on Toymods is probably reason enough to let you get away with asking for advice on keeping cut springs captive but going forward you will realise people on here don't offer advice on doing anything dodgy and illegal.
    - Jackie Stewart
    Eltham vic
    that being said
    i took a pair of rear springs off the blue shitter to be re set 25 mm lower
    and the spring work guy only charged $10
    i said that was cheap , he said all we did was take a coil out
    but apparently they cut it with a high speed big arse cutter , then they quench it in oil straight away
    its the heat build up that occurs with a small angle grinder when cutting that alters the temper
    plus it sounds like unstable project cut the coils to much
    Aug 2010
    Also by cutting them they can't absorb as much energy, so you increase the chances of bottoming out the suspension. There's a reason lower springs have a greater spring rate.
    Jun 2010
    shorter stroke shocks to keep everything captive??
    May 2006
    tas
    geez you lot are a bunch of chickens. ive had cut springs in my car, mate have etc etc, never had a serious issue.
    use some zippie ties to keep them in place.
    pull the switch out and poke a multi meter in there and see if the switch is putting out power when its pressed. if not then your switch is stuffed, may just need something resoldering or could be proper broken or worn out.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    but he does have a serious issue
    adn in NSW we actually have roadworthy checks, and.. as he sounds a bit like a young fella, is inviting a reaming by a "nice" cop/RTA dude when they see the car bouncing along, looking like it has 2 coils out
    just accept 2 coils was not a good idea, get some near free normal springs, or just spend the $200 or whatever on K-macs (or something better) $200 is not a lot of burgers
    By The Witzl in forum FAQ
  2. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 01:31 AM
  3. How do you take rear seats off 78 cressida?
    By subtract_division in forum Tech and Conversions
    Last Post: 11-03-2009, 10:45 PM
